Problem with rear pads - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2005, 03:46 PM   #1 (permalink)
Solorange's Avatar
View Solorange's Photo Gallery
I replaced my rear brake pads today and now i can hear them rub ever so slightly. I was wondering if that is normal when you first change them. I compressed the cylinder with a c clamp in the caliper. Will they stop rubbing after i drive the car a bit and they were down a bit? Thanks in advance for the response.
99 Toyota Solara SE V6 5spd
09 Toyota Highlander Sport
05 Jeep Wrangler Rubicon
http://www.cardomain.com/ride/2086758
Solorange is offline   Reply With Quote
Old 06-05-2005, 07:33 PM   #2 (permalink)
Solorange's Avatar
So nobody has changed their own brake pads before? I was hoping to get a response.
Old 06-05-2005, 07:38 PM   #3 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700865
iTrader Score: 6 reviews
View EKam's Photo Gallery
What kind of rubbing noise is it making? What brand of pads did you use?
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 06-06-2005, 02:43 PM   #4 (permalink)
Gameroom cash: $304455
I had this problem on my 94 Camry with 4 wheels discs. I just replaced the rear pads for the first time and didn't bother to cut the rotors. It turns out the new aftermarket pads I used were a little bit bigger (wider) than the OEM Toyota pads and were now making contact with an area of the rotor that was rusty. It took me a while to figure this out. The noise went away in about 1000 miles of driving as the pads simply wore down the rust. This may be your problem.
Mike
Mike Gerber is online now   Reply With Quote
Old 06-07-2005, 02:18 AM   #5 (permalink)
View 500KCamry's Photo Gallery
I haven't noticed a rubbing sound when I've done mine, but I replaced with Toyota pads. What Mike --^-- says if you used another pad type. Another thing, maybe the caliper isn't sliding easily on its posts? Did you grease em?
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
