Camry & E-85 Gasoline? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2005, 11:34 PM   #1 (permalink)
2001 Camry LE
View Nuke209's Photo Gallery
Was pumping gas and noticed E-85 Methanol (85% mininum) and was wondering if Camry's (any gen) can run it in their system
Seriously tho
Nuke209 is offline   Reply With Quote
Old 06-04-2005, 11:56 PM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
E-85 is Ethanol.
M-85 is Methanol.
(85% alchohol - 15% gasoline)
If you used M-85, the engine proably wouldn't be running by the end of two years. Meth is highly corrosive, and Aluminum will not stand up to it for a long amount of time. Ethanol (grain alchohol) is corrosive, but not nearly as much.
You can not use either in a gas engine. You will run into sever problems across the board. From them fuel system, seals of various types, everything it comes into contact (minus piston rings and valves) corroding over time.
You can run gashol in a normal engine without a problem. That is typically 90% gasoline, and 10% E-85.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 06-05-2005, 12:07 AM   #3 (permalink)
2001 Camry LE
My bad, I meant Ethanol
I know that most gas stations here use gashol
