Car not starting right away - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2005, 02:00 AM   #1 (permalink)
View mehul's Photo Gallery
I have a 1995 camry which refuses to start immediately. I m a novice at cars, and new to the forum. I always have to hit the gas pedal while turning the ignition key for the car to start over!
Wht could be possibly wrong?
mehul is offline   Reply With Quote
Old 06-05-2005, 03:16 AM   #2 (permalink)
View 500KCamry's Photo Gallery
If yours is a 2.2L I4 maybe the temperature sensor. It increases the fuel injector pulses for a cold start.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-09-2005, 03:28 PM   #3 (permalink)
What do I have to do to fix it? Or see if that is the problem?
Old 06-09-2005, 03:34 PM   #4 (permalink)
The V6 has a cold start injector, the I4 uses the Engine Coolant Temperature sensor to cause the injectors to spit more fuel at start up. What engine do you have?
01 XLE V6 310K km
Old 06-09-2005, 03:35 PM   #5 (permalink)
I got a V4.
Old 06-09-2005, 04:11 PM   #6 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Eh... you mean I4... there's no such thing as a V4.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 06-09-2005, 04:15 PM   #7 (permalink)
Advanced Noob
brungold's Avatar
View brungold's Photo Gallery
you also may need to clean your throttle body, or even upgrade your grounding
| 1995 Camry LE 5SFE [sold] | 2003 Highlander 1MZFE [sold] | 2006 Tacoma PreRunner 1GRFE [gone] | 2008.5 Audi A3 2.0T [now]
FS: Navone N-85V Line-Out Convertor for connecting amp/sub to Factory HU
brungold is offline   Reply With Quote
Old 06-09-2005, 05:22 PM   #8 (permalink)
View pmohr's Photo Gallery
Not anymore, but there was - http://en.wikipedia.org/wiki/V4_%28engine%29
pmohr is offline   Reply With Quote
Old 06-09-2005, 05:59 PM   #9 (permalink)
I am reading a lot on this(through repair manuals and such) so I just need little guidelines.
What did you mean by upgrading the grounding?and cleaning the throttle body? (Layman terms might help)
And yes, my engine is I4.
Also, if there is a hole in the coolant box(topside)..can the coolant evaporate? It is empty and I didnt notice any leaks.
Thanks y'll!
Old 06-09-2005, 06:58 PM   #10 (permalink)
Advanced Noob
brungold's Avatar
factory grounding wires are tiny, upgrade the "big three" with 8ga wire may improve your problem
1) Battery negative to chassis
2) Alternator to battery positive
3) Chassis to engine
http://forum.sounddomain.com/forum/u...=5;t=007801;p=
and heres a tutorial for cleaning the TB:
http://www.4x4wire.com/toyota/mainte...throttle_body/
got these from doing a quick search on the forums here
good luck!
