HELP! will these rimz fit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2005, 02:07 AM   #1 (permalink)
-= CAMRY =-
View pk_kk's Photo Gallery
4th Generation HELP! will these rimz fit
I know alot of people are saying alot of things about sizes for rimz i need to know if this will fit on my 1998 camry
size is 17"x7, 5x100/5x114.3 bolt pattern, +40mm offset.
i really really want these but i do not know if it will a proper fit
and if it does fit will i be limited to tire sizes.and how low can i lower my car with rimz tires.
http://www.toyotanation.com/forum/t79038.html
http://www.cardomain.com/id/pk_kk
pk_kk is offline   Reply With Quote
Old 06-06-2005, 02:34 AM   #2 (permalink)
The Greatest
View CamNub's Photo Gallery
should fit if you use the 5X114.3 bolt pattern.
CamNub is offline   Reply With Quote
Old 06-06-2005, 02:46 AM   #3 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
You are going to be limited in tire size. 205/40-215/35 should work well on that rim with no rubbing against your fender.
If you are still anxious, jump on http://www.tirerack.com and find a similar size rim and check what your options are
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 06-06-2005, 01:27 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
^ actaully, his tire options are pretty fair... 215/45/17 (most common, but slightly undersized), 225/40/17, 215/50/17
I would go with the 225 series, because it looks more aggressive with the width
HaHa
Old 06-06-2005, 01:37 PM   #5 (permalink)
View 604-Mico's Photo Gallery
^^ agreee with above
Userlain i think he has a gen4...not a gen2
so 205/40, 215/35 is a bit too small
'94 1mzfe Coupe
2.5" dropzones
Tokico Blues
Gen 3 Camry SE wheels
APS-996 Alarm-Starter Combo
604-Mico is offline   Reply With Quote
Old 06-06-2005, 02:42 PM   #6 (permalink)
Sleeper Camry
View Kirby Dude's Photo Gallery
I've got the same car as you and I have 17x7 with 38 offset (smaller the number, the further it stick out). I'm running 225/45/17 Yoko ES100 (previously 215/45/17- harsher ride). The tires rub a bit only when someone is in the back and we go over a bump. With your 40 offset, you might be able to get away with the same tire size(225/45/17), otherwise I would recommend 215/50/17 if you want to play it safe. BTW: are you lowering the car?
Kirby Dude is offline   Reply With Quote
