1MZ - AFC set up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2005, 05:22 PM   #1 (permalink)
Sleeper Camry
View Kirby Dude's Photo Gallery
1MZ - AFC set up
If you're running an AFC, I just like to compare your setting with mine. Please state if you have an s/c, what psi, %hi/low throttle, RMP intervals at hi/low and your correction. This is what mine are.
I'm using an SAFC-II, S/C with 6lbs on 1MZ
Throttle low=10%, high=80%
RPM LOW (%) HIGH(%)
1000 0 0
1600 0 0
2200 +10 0
2800 +15 +5
3400 +20 +5
4000 +10 +5
4600 0 +5
5200 0 +5
5800 0 +5
6400 0 +5
7000 0 0
7600 0 0
Comments welcome.
Kirby Dude is offline   Reply With Quote
Old 06-06-2005, 05:30 PM   #2 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Kirby, if you still have mine scribbled down, would you mine posting for me? Otherwise, I'll have to check when I get home.
If you do post...I'm using SAFC I, 4psi, stock injectors, automatic.
So did you end up getting Yoshio to look at your settings again?
Edit: forgot to mention I'm on stock injectors.
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 06-06-2005, 05:37 PM   #3 (permalink)
Sleeper Camry
This is Phi's set up.
Throttle low=35%, high=80%
RPM LOW (%) HIGH(%)
1000 0 0
2000 0 +6
2500 0 +7
3000 0 +8
3500 0 +8
4000 0 +7
5000 0 +5
6000 0 +4
I spoke to Yoshio, he said I could play with the settings. The only warning he gave was not to go into negative correction. So, I've changes my setting to the same as yours. I'll have to run it a couple of days to see if there is a change. BTW: read your e-mail.
Old 06-07-2005, 07:37 AM   #4 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
Thx for posting Kirby.
Nobody else here has an SAFC on their SC'd 1MZ?
