A/C reduces engine speed drastically - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2005, 12:37 PM   #1 (permalink)
View T-Heazy's Photo Gallery
4th Generation A/C reduces engine speed drastically
Hello,
I have a 97 4cyl camry automatic. I ran the engine extremly hot to the point that I needed a new engine. I recently had a new engine installed and the car runs great. The only prob is anytime I turn the A/C on i lose a lot a power. Especially in 1st and 2nd gear. Do you guys have any ideas would could be causing this problem? Unfortunately the problem isn't prompting a check engine light. I had someone check the pressure on the fuel filter and fuel pump and was told that the pressure was ok.
T-Heazy is offline   Reply With Quote
Old 06-07-2005, 12:39 PM   #2 (permalink)
Mitsubishi Diamante Owner
CDub LXi's Avatar
View CDub LXi's Photo Gallery
A/C always robs power.. and fuel economy. It's normal.
Honestly.... what kind of question is this?
CDub LXi is offline   Reply With Quote
Old 06-07-2005, 12:39 PM   #3 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
if its really alot, like more than what you would normally loose by turning on the AC, check the tension on the belt that runs the AC compressor, and check the pulley on the compressor and make sure it turns freely.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 06-07-2005, 12:41 PM   #4 (permalink)
View 500KCamry's Photo Gallery
There's a A/C idle up switch which increases the idle speed by a few hundred RPM when the A/C is used. Check in neutral and idle, does it work?
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-07-2005, 02:08 PM   #5 (permalink)
I understand that the A/C reduces power and fuel efficeincy but not as drastic in my case. I've had the car for 3 years and this is the first time i've experienced this problem. I'm hoping this problem is outside of the recent engine install
I'll check the belt tension and the pulley as suggested. I'll also run the idle switch test in neutral. Thanks for your immediate response.
I'll keep you all posted.
Old 06-07-2005, 02:11 PM   #6 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
The A/C idle up isn't working.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 06-10-2005, 04:13 PM   #7 (permalink)
It seems as though it is Idle-ing up a bit. I see the RPM move just a little. Could an EGR valve be the problem.
Old 06-11-2005, 01:06 AM   #8 (permalink)
View weaktruk's Photo Gallery
Originally Posted by T-Heazy
Hello,
It is very clear that if you run an engine so hot, that you destroy it, that you would also not be able to notice any drag an A/C system has on an engine. Come on fella, read your own post and see if makes ANY sense!
weaktruk is offline   Reply With Quote
Old 06-11-2005, 07:21 AM   #9 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
In my clipse when the a/c is on you can really feel how it robs away the low end power. after the rpms jump about 2,500 then the car picks up and shoots off
http://www.xclusive.bz
Old 06-11-2005, 10:41 AM   #10 (permalink)
Thanks weaktruk, that was pretty helpful.. get a life
