Used Camry Inspection Checklist? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2005, 11:46 AM   #1 (permalink)
View rstl99a's Photo Gallery
Hi all,
I searched but could not find a reference in past postings.
Is there a "Used Camry Inspection Checklist" somewhere, pointing out the particular things to look for when inspecting a used Camry (mechanical, electrical, rust, ride, etc.)?
If not, what are some of the more important things to look at or get checked out by a mechanic, to prevent nasty surprises down the road (I'm not referring to typical checks like engine smoke, hard shifting, brakes, exhaust, suspension, etc., but more "hidden" faults that could cause grief if not adequately assessed before buying).
I am looking for a Gen 3 model.
Thanks!
--Robert
rstl99a is offline   Reply With Quote
Old 06-09-2005, 12:17 PM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
If it's a v6 take a strong flashlight and look at the back of the engine for fresh oil.
If it's just at the bottom, the rear main seal is leaking, the middle is a blown head gasket, close to the top is a valve cover gasket.
Other than that it's just normal car stuff.
Check that the A/C blows cold air in a fairly short amount of time. If not, tell them they should recharge it. (When mine was recharged the first time at the dealer, it went from having cold A/C in twenty seconds on the first drive, to ice cold air after five seconds) Woot woot for freon!
Take a napkin and pull the transmission fluid dip stick out. You want red-pink color fluid. If it's not, tell the sales guy it needs to be FLUSHED. (I do that anyways. I'm mean, and I like new transmission fluid!)
^ If they do that, along the same lines, the power steering fluid should be any red color (It's tranmission fluid) :P aaaaand the differential fluid should be changed if it's high milage. :P
If you want to be anal, inspect the CV joint covers. No cracks!
The sales guys TELL the mechanics what to do. If you could talk a sales guy into believing something fairly minor is broken, they'll MAKE the mechanics fix it just so the car get's off the lot.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 06-09-2005, 01:34 PM   #3 (permalink)
View karazy's Photo Gallery
I think they have a copy of the certified vehicle inspection list at toyota.com. That would be a good place to start.
karazy is offline   Reply With Quote
Old 06-09-2005, 01:37 PM   #4 (permalink)
Thanks for those suggestions. There are obviously a lot of generic "used car inspection checklists" out there to use, but I was looking for some specific bits and pieces that should be checked closely on a used Camry, to prevent nasty surprises post-sale.
In my case, I'm looking for a vehicle sold by an individual, and not a dealer (don't trust used car dealers, especially the corner-lot ones who get their cars from auctions etc.). Hence the need to focus in on the key areas in my inspection. I have a mechanic that I can take the used car to for his inspection, but that may not always be practical hence the idea of my having a good look at the car myself, and being able to make a decision on buy/no-buy.
In a way, Camry's are reputed to be such solidly built and reliable cars that it takes a lot of the worry out of buying a used one, but no one wants to be stuck with a lemon, or with one that has been grossly under-maintained by a hapless previous owner. One of the reasons I much prefer buying from an individual is that this allows me to size up that person's maintenance approach, look at repair/oil change records, etc. Often, you have none of this information when you buy from a used car dealer, who knows little about the past history, and couldn't care less, as long as he can sell you the car and have it last the 30 day (or whatever) warranty without incurring major problems; after that point, you're on your own!
If anyone else has good tips on what to look for, I'd love to hear. Thanks!
Old 06-09-2005, 02:06 PM   #5 (permalink)
Here's the Toyota Certified Used Car Checklist referred to above. Indeed, looks quite comprehensive, so if someone is looking to buy a reasonably new vehicle with low mileage, and willing to pay the premium involved in buying from Toyota, it probably helps ensure a fairly safe buying experience. I'm looking to buy a mid-90's Camry so I assume that none of these would go through Toyota certification, but the list may give some ideas of what to look for myself:
VEHICLE HISTORY
Run and print Vehicle History Report/Check for outstanding Special Service Campaigns
EMISSIONS & STATE INSPECTION
Perform emissions test and/or state inspection, if required
FRAME, STRUCTURE & UNDERBODY
Frame/Unibody check
Inspect body surface
Inspect panel alignment and fit
Inspect lower body and underbody for damage
Check exhaust systems and hangers
ENGINE COMPARTMENT
Change engine oil and filter
Check for evidence of sludge
Inspect for fuel, oil, coolant or other fluid leaks
Engine cold high idle correct
No abnormal engine noise at cold start
Throttle does not stick shut on cold start
Drivability OK during warm-up
Hot drivability OK
Engine reaches normal operating temperature
Engine fan functions properly
No excessive drone or vibration from engine
Drive belts and hoses free of cracks or damage
No damage to engine mounts
Check under-hood labels and decals
Engine compartment is clean
Under-hood heat insulator pad is clean
Engine free of excessive dressing
Inspect air filter
Oil, brake, clutch, transmission, transfer case, washer and power steering fluid levels OK
Under-hood fluids clear and uncontaminated
BATTERY SYSTEM
Battery in good condition, has proper cold cranking amps and reserve capacity
Battery proper size and secure
Battery posts free of corrosion
Cables in good condition
ENGINE COOLANT & HVAC SYSTEM
Engine coolant at proper hot and cold levels
Coolant specific gravity to -31° Fahrenheit
A/C cooling operation normal
A/C refrigerant sight glass clear
Heater operation normal
BRAKING SYSTEM
Inspect brakes, calipers, lines and hoses
No excessive vibration during braking
ABS operates on "panic stop"
Parking brake sets and holds vehicle
Brake pads/shoes must have minimum of 50% wear remaining
No excessive grooving or heat checking of rotors or drums
Parking brake releases completely
Brake pedal free play and travel is normal
TRANSMISSION/TRANSAXLE
Transmission/clutch operates smoothly
Automatic transmission in "ECT" power mode shifts properly
Transmission gear ranges engage promptly while shifting when warmed up
Transmission shift lock and key interlock system OK
Transmission does not shift into overdrive when button is in OFF position
Inspect transmission case and pan for leaks
No damage to drive and axle shafts
Differential fluid level correct
STEERING SYSTEM
Steering has normal feel in lock-to-lock turning
Steering wheel centered in straight line driving
Vehicle tracks and drives straight on level surface
Tilt steering wheel adjustment works properly
No excessive wind whistle or buzz
No excessive tire vibration or steering wheel shimmy at any speed
Interior free of significant squeaks or rattles
Inspect steering rack, linkage, bushings, control arms and dust boots
TIRES & SUSPENSION SYSTEM
Inspect tires for defects, damage and inflation
Minimum of 5/32" tread depth remaining across tread width
All four tires must be of same brand, model, size, tread design, speed and load rating
Wheels are clean and free of brake dust
Tires are dressed, not greasy
Wheel cover caps secure with no damage
Inspect struts/shocks for leaks and wear
No damage to CV joints/boots
LIGHTING SYSTEMS
Warning lights function
High and low beams OK
Headlight aim is OK
Taillights work
Brake lights work
Side marker lights work
Backup lights work
License plate lights work
Instrument lights work
Heater lights work
Dash light dimmer works
Turn signals operate correctly and self-cancel
Four-way flashers work
Defogger indicator light turns on with switch ON
Dome/courtesy lights operate with door cycles
INSTRUMENT PANEL & ELECTRONIC SYSTEMS
Master key is present
Fuel gauge reads correctly
Battery voltage gauge reads correctly
Horn works
Airbag deployment/replaced airbag
Speedometer and odometer work properly
Cruise control operation normal
Clock keeps time
All wiper speeds work correctly
Windshield washer operates
Wiper blades are in good condition and work
Wipers return to correct position when OFF
All mirrors have full range of adjustment
Windows operate normally
Window locks operate normally
Power windows operate from master switch and all door switches
Memory seat control operates properly
AUDIO & ALARM SYSTEMS
Audio/cassette/CD system working normally, CD cartridge present (if equipped)
Antenna is present and functions properly
Radio speakers do not rattle at high volume
Remote entry system works properly
Theft-deterrent system works properly
INTERIOR CONDITION & APPEARANCE
Day/night mirror operates and lens is good
Window tinting clear and free of bubbles
Cigarette lighter is intact and operates
Ashtrays function and are in good condition
Ashtrays and lighter are clean; no evidence of use
Headliner, sun visors, dash pad, upholstery, console, cup holders, trim panels, floor mats and carpets are in place and in good condition
Cup holder extends completely and sturdily
Doors open and close correctly
Door locks, including child safety locks, work properly
Seats, including all position adjusters, work properly
Headrests function properly
Rear defogger grid lines intact
Interior leather, vinyl, plastic, carpet and fabric surfaces are free of holes, rips, tears, excessive wear or fading
No evidence of previous improper repairs
Inspect seatbelt condition
Seatbelts have full range of extension and smooth operation
Seatbelts lock up per specification
Inside remote release operates normally
Interior is free of debris
Dash and vents are clean and properly dressed
All crevices are clean
Doorjambs are clean
Glove box and console compartments are clean
Seats, carpets, floor mats and headliner are free of stains
Free of odor, including heavy perfume
Glass is clean and free of streaks
EXTERIOR CONDITION & APPEARANCE
Exterior is clean and free of road residue
No cracked or broken lenses of exterior lights
Outside rearview mirror operates/lens is good
Glass free of cracks, stars and large chips
Glass is free of improper repairs
Bumpers are free of cuts, gouges and scratches
Body is free of all dents
Body is reasonably free of dings
Paint is reasonably free of scratches and chips
Vehicle is free of improper paint repairs or mismatched color
Hood and trunk latches working
Free of water spots
Paint is free of swirl marks
Paint has even, high luster
Paint is free of buffable scratches
Free of wax residue
Wheelwells are clean
Acceptable aftermarket items checked
Removal of unacceptable aftermarket items
TRUNK COMPARTMENT & SPARE
Trunk is clean, free of debris, no stains
Trunk light and trunk trim appearance
Jack and tools are correct, present and secured
Fiber board tire cover is not broken/warped
Spare tire present
Spare tire and storage areas are clean
Spare tire is securely fastened
No signs of damage to spare tire
Minimum 5/32" tread remaining on spare
Spare tire has correct air pressure
HYBRID COMPONENTS
Hybrid Vehicle Immobilizer System
Multi-Information Display
Inverter Coolant Level
Engine and ECT (Electronically Controlled Transmission)
ABS (Anti-lock Brake System)
EMPS (Electric Motor Assisted Power Steering)
CCS (Cruise Control System)
SRS (Supplemental Restraint System) Airbag
HV ECU (Hybrid Vehicle Electronic Control Unit)
HV (Hybrid Vehicle) Battery
Perform "Onboard Equalizing Charge" of HV Battery using Intelligent Tester
Fully charge 12-Volt Auxiliary Battery
Clean or replace Air Refiner Filter (A/C or evaporator filter)
Check Transaxle "Park" Mechanism
ADDITIONAL ITEMS, WHERE APPLICABLE
"Fade-away" dome light works properly
Sunroof/convertible top operates normally through full range of positions
Convertible top lockout function operates
Radio security codes cleared
Navigation system works properly
Transfer case smoothly switches from 2WD to 4WD and back from 4WD to 2WD
Truck bed is in good condition
Truck bedliner is in good condition and secured
Tailgate functions properly
Rear bumper is in good condition and secured
