p1133 - Heated o2 sensor circuit slow response (Bank 1 Sensor 1 i.e. rear)
Responce time for the heated oxygen sensor's voltage output to change from rich to lean, or from lean to rich, is 1 sec. or more during idling after the engine is warmed up. (2 trip logic)
p1135 - Heated Oxygen sensor Heater Circuit malfunction (Bank 1 sensor 1 i.e. rear)
When the heater operates, heater current exceeds 2 A or voltage drop for the heater circuit exceeds 5v. (2 trip logic)
And/Or
Heater current of 0.25 A or less when the heater operates. (2 trip detection logic)
Replace the sensor.
Are the other two codes coolant temp sensor related?
AIM/Yahoo Toysrme257th
Now with Turbo!
