Camry Feels Stuck, Help? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2005, 11:28 PM   #1 (permalink)
2001 Camry LE
View Nuke209's Photo Gallery
4th Generation Camry Feels Stuck, Help?
When driving, then coming to a stop, then going again, the car feels slow and stuck, as if something was wrong with the throttle
Kinda feels like somethings holding the car back
Any ideas?
Nuke209 is offline   Reply With Quote
Old 06-10-2005, 01:06 AM   #2 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
My camry had the same feeling. So does my clipse, but that's only when the a/c is on. Maybe it's your a/c. Or if you haven't try changing you plugs, wires, fuel filter air filter and pour in some fuel injector cleaner in your tank.
http://www.xclusive.bz
Old 06-10-2005, 01:22 AM   #3 (permalink)
Carzzz's Avatar
View Carzzz's Photo Gallery
lacks low-end torque
Carzzz is offline   Reply With Quote
Old 06-10-2005, 02:25 AM   #4 (permalink)
99 Camry LE
View Gachinto's Photo Gallery
Don't Stop :d
Gachinto is offline   Reply With Quote
Old 06-10-2005, 03:35 AM   #5 (permalink)
View karazy's Photo Gallery
Maybe you have a sticky caliper.
karazy is offline   Reply With Quote
Old 06-10-2005, 09:00 AM   #6 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
check ur trottle body, is the trottle line tight enough (not too much play)
skewe is offline   Reply With Quote
Old 06-10-2005, 09:23 AM   #7 (permalink)
2001 Camry LE
Hm...probably because AC is on, because heat was kicking in and i've left the AC on, but will try without it
I dont know if it's tight enough (the throttle line)
I've changed my plugs and wires, used fuel injector, sea foam, and i have an intake, so air filter is there.
Old 06-10-2005, 10:47 AM   #8 (permalink)
2001 Camry LE
with the ac on and off, same thing, but will check the throttle line
Old 06-10-2005, 02:48 PM   #9 (permalink)
View 500KCamry's Photo Gallery
If an automatic, also check your transmission fluid.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-10-2005, 03:50 PM   #10 (permalink)
Are the rpms increasing when this is happening or is the delay actually with the fuel getting to the engine?
