What could be the problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2002, 06:59 PM   #1 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
Earlier today, I started up my Camry and a big cloud of smoke came out of the exhaust. If it helps, it was the first time I started the car today. What could be the problem(s).
TheKevin is offline   Reply With Quote
Old 08-29-2002, 07:17 PM   #2 (permalink)
View Deep's Photo Gallery
Could be bad valve seals or rings. Or when the car was stored the owner put a teaspoon of oil in each cylinder to keep it from seizing. What car was this?
Deep is offline   Reply With Quote
Old 08-29-2002, 07:27 PM   #3 (permalink)
TheKevin's Avatar
'92 Camry V6
Old 08-29-2002, 09:07 PM   #4 (permalink)
A Worthless Asset
Location: An island full of diseased monkeys an hour southeast of Houston
View 4DoorsofFury's Photo Gallery
oil leak of some kind is my guess. might wanna take it to some professionals and run diagnostics.
...living life like both a speeding bullet and a calm breeze...
Scratch the 5S-FTE idea...I'm just a poor college student, but I can wait because in a few years ill be going 600 mph 100 feet above the ground.
4DoorsofFury is offline   Reply With Quote
Old 08-29-2002, 11:25 PM   #5 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
i get the same thing, same car, leaky valve guides i`m guessing, haven`t had it looked after yet, but hey oil is cheap!
-Nick
Nick is offline   Reply With Quote
Old 08-30-2002, 12:44 PM   #6 (permalink)
TheKevin's Avatar
Is it a costly reapir if it is bad valve seals or rings?
Old 08-30-2002, 12:57 PM   #7 (permalink)
Gen2 Camry
View 91camryDX's Photo Gallery
Try using the "no smoke" treatments. If that doesn't fix the problem then try your mechanic. I burn about 1/4 to 1/2 a quart every 3k miles, so I don't really feel the need to have it fixed to save 2 bucks of oil every year.
1991 Toyota Camry DX: Mods listed on Cardomain
http://www.cardomain.com/id/whitecamrydx
91camryDX is offline   Reply With Quote
Old 08-30-2002, 04:45 PM   #8 (permalink)
TheKevin's Avatar
Ok, I'll try those smoke treatment things. Do you prefer a brand or any one will do? If it helps, my Camry has 155K miles.
Old 08-30-2002, 06:25 PM   #9 (permalink)
DJModifyd
alex's Avatar
View alex's Photo Gallery
my supra puffed a bit of smoke when it started, i put in some of that no smoke crap......worked like a charm. no smoke what so ever
alex is offline   Reply With Quote
Old 08-30-2002, 09:44 PM   #10 (permalink)
TheKevin's Avatar
Alex, was oil leaking from underneath the car too? Also, what "no smoke treatment" did you use?
Old 08-31-2002, 05:21 AM   #11 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
If oil is leaking from underneath the car you got problems elsewhere.
Try Bardohl's No Smoke. It looks like 1000W oil (its thick).
I've seen it at Autozone and my buddie and I were making fun of it. I said damn you don't piston rings if you pour this sh*t in your engine.
Anyways my 3S-FE puffs out a cloud of blue smoke on start up. It only does it when the engine the cold.
The puff of blue smoke is from worn valve seals. They go bad overtime and allow oil to seep pass the valves into the combustion chamber were it gets burned up (blue smoke).
If its not using up alot of oil I wouldn't worry about it unless it bothers you.
"Skoolin' the unlearned!"
Old 08-31-2002, 02:21 PM   #12 (permalink)
TheKevin's Avatar
What are the downsides/dangers of using these products?
Old 08-31-2002, 11:21 PM   #13 (permalink)
TheKevin's Avatar
What are the downsides/dangers with using these products?
Old 08-31-2002, 11:28 PM   #14 (permalink)
View PLRBEAR's Photo Gallery
Downside= You're not actually fixing the cause of the problem...just prolonging the interim.
'99 Camry 5S-FE
PLRBEAR is offline   Reply With Quote
Old 09-03-2002, 01:26 AM   #15 (permalink)
TheKevin's Avatar
How much should I expect to pay to have the valve seals/rings replaced. What else would need to be replaced/worked on?
