Removing Dash - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2005, 02:49 PM   #1 (permalink)
99 Camry LE
View Gachinto's Photo Gallery
4th Generation Removing Dash
Any sites with picture instructions for removing the entire front panel / dash? There is a way that does not require the removal of the steering wheel right? Prefer the easiest way. Planning to spray paint some parts.
Gachinto is offline   Reply With Quote
Old 06-10-2005, 04:14 PM   #2 (permalink)
View asheik9201987's Photo Gallery
i'm lookin to do this also i'll let you know if i find out anything.
asheik9201987 is offline   Reply With Quote
Old 06-10-2005, 04:15 PM   #3 (permalink)
camry-4-ever's Avatar
View camry-4-ever's Photo Gallery
Have you done a search on here? I believe this has been covered a few times on here.
camry-4-ever is offline   Reply With Quote
Old 06-10-2005, 05:11 PM   #4 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
Most of the trim u can just pull straight off
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 06-10-2005, 06:29 PM   #5 (permalink)
The Guinea Pig
N Somniac's Avatar
View N Somniac's Photo Gallery
remove your steering wheel cover (the two plastic pieces) and look under the steering wheel, on newer ones there are two 12mm bolts that attach the steering wheel to the dash frame.. once these are removed the entire assembly should pivit downwards, getting it out of your way, no need to unhook anything, or need any special equipment, it just angles it out of your way.. try that, if it has these bolts, it should be smoooth sailing, if not, a lil patience should be enough, oh and a lil wiggling
1996 Camry 5S-FE Mods started in 2005
My crappy non updated yahoo site
Will have a Car Domain Site Soon
N Somniac is offline   Reply With Quote
Old 06-14-2005, 11:20 PM   #6 (permalink)
99 Camry LE
Can't avoid to NOT UNBOLT the steer wheel ? What about the air bags, the passenger one, would it be affected by the removal of dash ?
Edit:
I did search, maybe I didn't use the right keyword.
Old 12-23-2005, 12:59 PM   #7 (permalink)
The Biggest comment Whore
Avalonman's Avatar
View Avalonman's Photo Gallery
Gen5
I was wondering if I could do the same thing with my Gen5
Avalonman is offline   Reply With Quote
Old 12-23-2005, 04:16 PM   #8 (permalink)
-= CAMRY =-
View pk_kk's Photo Gallery
^ it's should be the same for Gen 5 best thing is to get a haynes manual
http://www.cardomain.com/id/pk_kk
pk_kk is offline   Reply With Quote
