PCV Valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2005, 05:56 PM   #1 (permalink)
Camryfanatic's Avatar
View Camryfanatic's Photo Gallery
3rd Generation PCV Valve
Can someone tell me where exactly its located? I have a chilton manual, but the pictures are useless to me. I would like it if some could post a picture that exactly shows where it is, that would be nice.
Camryfanatic is offline   Reply With Quote
Old 06-10-2005, 06:26 PM   #2 (permalink)
View 500KCamry's Photo Gallery
I4 or which V6?
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-10-2005, 06:38 PM   #3 (permalink)
Breakin' necks since '02!
Durrby's Avatar
iTrader Score: 12 reviews
View Durrby's Photo Gallery
If it's a 4 banger here's where it is......it's the circled part!
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
Durrby is offline   Reply With Quote
Old 06-10-2005, 07:39 PM   #4 (permalink)
What is the right way of taking it off and then putting a new one on?
Old 06-10-2005, 07:43 PM   #5 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
Use a set of pliers to undo the quick-connect clamps, removing the rubber hose going to the upper intake. Leave the other end attached to the PCV valve, then tug up and to the side (there's a notch in the PCV valve that corresponds with a notch in the valve cover). Then, take the hose off the old PCV valve and attach it to the new one. From there installation is the reverse of removal.
If the clamps fight you, it's ten minutes tops.
Steve
'08 Camry LE 5-speed. Traded for an '04 Mustang GT.
87Camry5Speed is offline   Reply With Quote
Old 06-11-2005, 01:06 AM   #6 (permalink)
Will I see a improvement? I don't know the last time if it was changed or if it ever has been changed at all?
Old 06-11-2005, 02:31 AM   #7 (permalink)
If you do a search of PCV, you'll find a mod that a fellow posted (think Toysrme is the poster).
Its a way to rig a more effective oil trap. The oil blow by eventually gums up the throttle body, throttle flap, vacuum ports and IAC (ISC) valve. Changing the PCV is one thing to fix, the other is to clean the throttle body occasionally.
01 XLE V6 310K km
