Originally Posted by Diehonda
OR take yours off and try to rethread it with a rethreader. You will have to take the plug to the parts store with you to find out what thread it is, and also get a new gasket.
I totally agree with your suggestions. I will check out the self tapping plugs.
In your above quote, you mentioned to remove pan to rethread. would this be because of metal shavings possibly getting into the oil thus ruining the engine ?
Rethreading in small increments and cleaning between increments should help with shavings but there is always a chance that a metal shaving will get thru. This can also be true for the self tapping plugs.
It doesn't appear to me that rethreading is as common as the self tapping plugs and if that is true I wish I knew why.
THX
