Steering to the LEFT - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2005, 08:23 AM   #1 (permalink)
Registered User
View qprint's Photo Gallery
Went to dealer for a Vibration/Shaking effect and after they balanced and rotated tires, changed tires and wheels from another car and now it drifts to the left, especially at highway speeds. I know there's a NTHSA log on Camry's doing this and Toyota not finding a fix for it , but has anyone had a solution from there own mechanic or dealer ? This is unsafe for us drivers, and wears out the tires. I've read that the springs are the area of defect.I'll be on a lo
qprint is offline   Reply With Quote
Old 06-11-2005, 08:38 AM   #2 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
Get an Alignment
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 06-11-2005, 11:32 AM   #3 (permalink)
4u2nv
kasimmmmm's Avatar
View kasimmmmm's Photo Gallery
my cousin had the vibrating steering wheel when he needed a HUGE alignment. He hit a curb pretty bad. As for the steering to the left, mine steers to the right and its because it needs an alignment. If they aligned it and it still goes to the left, take it back. Its not done properly. Same thing happened to me.
kasimmmmm is offline   Reply With Quote
Old 06-11-2005, 01:09 PM   #4 (permalink)
Gameroom cash: $304455
Switch the 2 front tires/wheels with each other. If the car now pulls to the right you have found the problem. The tire (formally on the left) which is now on the right has what is known as a radial pull. The belts shift internally inside the tire causing this problem. The only cure is to replace the tire. If the car continues to pull to the left, the problem is in the alignment or the suspension components.
Mike
Mike Gerber is online now   Reply With Quote
Old 06-11-2005, 05:35 PM   #5 (permalink)
Registered User
Acoording to he NHTSA TSB's Alignments did nothing to solve the drifting to the Left problem.
The vibration has gone away and the right[driver side] rear tire was 2 PSI below all the other 3 tires. I put air in it to match the PSI on the other 3 adn the vibration came back. The drifting to the Left was lss than before. Shop Foreman asked me to go where I bought it adn get the tires replaced. Sounds to me like he pasing me away from his fault.
kasimmmmm: nice paint and tint: what color is the exterior ?
Old 06-11-2005, 06:43 PM   #6 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
The TSB is ST002-04 and applies to the Solara, Camry and Avalon - Issued on Feb. 4, 2004.
It instructs service to rotate the upper spring seat and if it still pulls left then to increase the right front camber and decrease the left front camber.
It worked fine until I fixed it!
csaxon is online now   Reply With Quote
Old 06-12-2005, 12:38 AM   #7 (permalink)
Registered User
Good Boy: Thats what I'm talking about guys. The TSB says it all. Drove car tonight and steering vibration and drifting to the Left. Going to Dealer Monday morning. Doubt Alignment will make the difference. If they tell me its the tires, I will ask for a written note for me to give to the Toyota dealer that sold me the car.
Old 06-12-2005, 02:12 AM   #8 (permalink)
Registered User
http://www.alldata.com/tsb/Toyota/11...-04/index.html
Here's my prrof.
Old 06-19-2005, 10:38 PM   #9 (permalink)
Registered User
Drove the car 500 km and the steering wheel and gas pedal vibrated at highway speeds. If I kept the speed constant, the vibration would come and go almost every 10 seconds. CV joints, wheel bearings, tires, alignment... I don't know ?
Old 06-24-2005, 10:28 AM   #10 (permalink)
Registered User
Got 4 tires balanced and a wheel alignment. Vibration minimized but car still drifts to Left. I give up.
Old 07-17-2005, 04:06 PM   #11 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
could it be the steering wheel/column? i just got an alignment and its doing the same thing, but to the right
toyotaholic is offline   Reply With Quote
Old 07-17-2005, 08:25 PM   #12 (permalink)
View 1C8 Streak's Photo Gallery
This wouldn't have anything with Toyota running Nascar in the future whould it?
1C8 Streak is offline   Reply With Quote
Old 07-19-2005, 09:05 AM   #13 (permalink)
View infantsam's Photo Gallery
I read teh TSB - but I can't understand the cutoff VIN as there are two numbers listed for my model - which one is the cutoff?
I'm going to dealer thursday - I'll post back up what happens.
BTW - this car rocks
'04 V6 SE
infantsam is offline   Reply With Quote
Old 07-19-2005, 09:18 AM   #14 (permalink)
NIGHT STALKER
throwback's Avatar
View throwback's Photo Gallery
the only thing i can tell you is get an allighnment
NIGHT STALKER
throwback is offline   Reply With Quote
Old 07-19-2005, 10:12 AM   #15 (permalink)
NIGHT STALKER
throwback's Avatar
wow seems to me like theres a strong problem i wish i could help but im out on this one.
NIGHT STALKER
