adapting after market battery - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2002, 11:59 PM   #1 (permalink)
View PES300's Photo Gallery
I would like to use a higher reserve capacity and cold cranking battery such as the terminator (walmart) but I have a problem with the stock batery cable what would you guys do
appreciate advise
93 camry v6 : :o
PES300 is offline   Reply With Quote
Old 08-30-2002, 09:01 AM   #2 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
You can lengthen the cables by using short connectors sold at Walmart as well. Make sure that it's secure or else you might have trouble starting your car.....
Silver Streak is offline   Reply With Quote
Old 08-31-2002, 10:41 PM   #3 (permalink)
View s2tigger's Photo Gallery
Or... You could just get what I got. Duralast - 34DTDGN - 900 CCA 120 Reserve $89.00 http://www.autozone.com/
-s2
s2tigger is offline   Reply With Quote
Old 09-01-2002, 12:29 AM   #4 (permalink)
Luc
View Luc's Photo Gallery
You can rewire all the power and ground cables also with thicker/equal gauge. I did that to my Gen4: power - 4-gauge to starter and 8-gauge to fusible link, ground - 2 4-gauge to engine block and chassis. Then add some fancy battery terminals.
Luc
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 09-03-2002, 08:09 AM   #5 (permalink)
I forgot to mention that I did in fact have to get some new battery terminals. It took a little while to "fashion" the old connectors to work properly. I think that it was worth it though.
-s2
