Air Fuel Ratio Gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-12-2005, 10:52 AM   #1 (permalink)
View smoky723's Photo Gallery
3rd Generation Air Fuel Ratio Gauge
ok i bought an air fuel ratio guage by autometer and i was wondering how to install it i have installed one on a supra befor u just wire it to the o2 sensor.. but i tryed that on mine the digital needle just goes crazy all the time except for wen i slow down.....i no you guys are gunna say it been posted yeah it was posted befor but no one answered
smoky723 is offline   Reply With Quote
Old 06-12-2005, 10:56 AM   #2 (permalink)
rusty9's Avatar
Gameroom cash: $442005
View rusty9's Photo Gallery
if its a 4 cylinder i do believe you need to wire it to the vF signal at the ecu or one of the diagnostics ports. if its a v6 then you'll have a vF1 and a vF2, one for each cylinder bank. dont ask me how to calibrate it tho
rusty9 is offline   Reply With Quote
Old 06-12-2005, 11:00 AM   #3 (permalink)
were do i put it on the ecu for a 4 cylinder
Old 06-12-2005, 11:17 AM   #4 (permalink)
rusty9's Avatar
well, the ecu is behind the glove box. so i would suggest using the diagnostics port under the steering wheel since its labeled. it would be much easier to get under there to splice in a wire then ripping out half your dash.
Old 06-12-2005, 11:19 AM   #5 (permalink)
ok which wire do i splice my diagnostic is under the hood
Old 06-12-2005, 11:22 AM   #6 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
That's all it's supposed to do...bouce back and forth, back and forth...like KITT's red red. It'll obviously show rich during WOT, and during decceleration, it'll have some other readings as well....
Silver Streak is offline   Reply With Quote
Old 06-12-2005, 11:23 AM   #7 (permalink)
rusty9's Avatar
like i said, splice the vF signal wire. the port under the hood is labeled too.
Old 06-12-2005, 11:33 AM   #8 (permalink)
ok well Silver Streak thats what it does but some times at WOT it goes a little down to lean and i dont see the vF signal wire label anywere
Old 06-12-2005, 12:17 PM   #9 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
You don't use the vF wires on an A/F gauge. vF is a 0-5v signal OBD-I ECU's output to show fuel trim. Not o2 data.
For o2 data, splice the o2 sensor wire<s>.
Tho vF data can be extremely handy when combined with o2 output, you can't substitute it.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 12-10-2005, 02:37 AM   #10 (permalink)
Custom Pimpin'
View camrykidd86's Photo Gallery
I just hooked mine up today, but the splices didn't work at all that came with the kit.. pisses me off, but yes, splice wire thru the o2 sensor wire um I can't remember what color everything is, but I can hit his back up tomorrow and tell you everything, but the headlight switch in the steering colum is Red with a blue stripe.. all I can remember.. thats for the 94 I'm not sure what year yours is, you should buy a Chilton manual if you dont' alraedy have one, great great great wiring diagrams
94LE Camry Inline-4
camrykidd86 is offline   Reply With Quote
Old 12-10-2005, 02:44 AM   #11 (permalink)
The 6&amp;quot;4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
You need a wideband o2 sensor for the A/F gauge to work properly
or else the gauge wl only flip between lean and rich
Zandro is offline   Reply With Quote
Old 12-10-2005, 08:28 AM   #12 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
^+1
Without a wideband, A/F gauges are useless.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 12-10-2005, 09:35 AM   #13 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
be like me. ask for a $300 aem wideband for christmas
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 12-10-2005, 10:54 AM   #14 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
when i had a Air Fuel Guage i tried hooking it into my oxygen sensor and never got it to work.... My car's 02 sensor had 4 wires coming off it, 2 Black, 1 Blue, and 1 White.....i used voltmeters to try to find the right one, but i never did.
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 12-10-2005, 06:46 PM   #15 (permalink)
View Ken4's Photo Gallery
Look for the OX1 terminal on the ECU. Connect your $10 multimeter there and one to the ground, and there you have it, a home-made AFR meter.
During closed looped (idling, low load) the voltage will fluctuate all over the place, .i.e. 0.3v~0.7v, which means the AFR is very close to stoichiometry 14.7. During open loop (aggressive driving), the voltage stabilizers around ~0.88v which means AFR is around 13.3. Use this chart as a reference.
http://www.zeitronix.com/questions/O2questions.htm
Ken4 is offline   Reply With Quote
