tire size!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-12-2005, 04:10 PM   #1 (permalink)
View Camry-rulez's Photo Gallery
3rd Generation tire size!!!
Will there fit to my Camry (3 gen) 195/65 R15 or 215/65 R15 (on the standart rims)???
Euro CAMRY. 3.0 GX V6 (auto.) 1993'
Toyota Camry and Peugeot 205 Driver
Camry-rulez is offline   Reply With Quote
Old 06-12-2005, 04:18 PM   #2 (permalink)
-=the wheel man=-
Killa_Kojak's Avatar
View Killa_Kojak's Photo Gallery
I4: 195/70HR14 14in x 5.5in wheel
v6: 205/65HR15 15in x 6in wheel
1993 Toyota Camry LE Sport-Unnaturally Aspirated then killed
1997 Toyota Camry LE- aKa Purgatory Gray
Killa_Kojak is offline   Reply With Quote
Old 06-12-2005, 04:22 PM   #3 (permalink)
I know but can I put on the oryginal rims 195 or even 215?
Old 06-12-2005, 04:26 PM   #4 (permalink)
-=the wheel man=-
215s should fit until told otherwise, i've added wider tires to my corolla with stock rims with no problems 175 to 185
Old 06-12-2005, 06:09 PM   #5 (permalink)
Gameroom cash: $101605
View kenny1773's Photo Gallery
I put 225/60/15 on my gen 3 V6 LE with stock steel rims, worked great.
When I went to replace them, I actually had some fool in a tire shop tell me there was NO WAY that size would fit on my car. I had to walk him outside and show him the ones I had on there and how worn out they were (proving they had been on there for 30k miles), he didn't believe me until he saw it. Then he went nuts trying to search for rub marks on the inner fender muttering something about no way they were on there without rub. He was wrong again
kenny1773 is offline   Reply With Quote
Old 06-12-2005, 06:22 PM   #6 (permalink)
-=the wheel man=-
^^^your lucky i asked the guys i got tires from to put on the wider ones ( had bad traction in winter ) then they acted like smartasses saying its not a ferrai and blah blah....i just said fuck it
Old 06-12-2005, 06:39 PM   #7 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
this is good information, considering i was told 225's would have rubbed, now im going to bring up another point, with getting wider tires, i'd like a little less sidewall, could 60 or 55 series tires work without making the speedo out of sync?
BlueFusion6851 is offline   Reply With Quote
Old 06-12-2005, 06:49 PM   #8 (permalink)
Rockin the STi
View onehotcamry's Photo Gallery
225 will not rub. I had no problems
bluefusion: I would think that keeping the stock rims and lowering the profile of the tire would throw it off a little. I don't know the stock tire profile, so not really sure how much it would throw it off. I could be wrong though.
04 WRB STi - Stg. 2
93 White Mr2T - 263 rwhp @ 10psi
95 Black Mr2T - TKO exhaust
04 Suzuki GSX-R600
onehotcamry is offline   Reply With Quote
Old 06-12-2005, 06:49 PM   #9 (permalink)
-=the wheel man=-
^^^stock is 65
Old 06-12-2005, 06:58 PM   #10 (permalink)
Rockin the STi
if you go from a 65 series down to a 55 series on the stock camry v6 rims(205/65/RH15) to (225/55/RH15) your speedometer will be off exactly 1.8 MPH which is 3.026 % too fast. The overall diameter of the tires/rims only increases 2.95%
I really don't see the need to worry about your speedometer being thrown off enough to be a problems/hazard.
04 WRB STi - Stg. 2
04 Suzuki GSX-R600
Old 06-12-2005, 07:00 PM   #11 (permalink)
-=the wheel man=-
^^^good excuse if you get pulled over though
Old 06-12-2005, 08:07 PM   #12 (permalink)
THis will help you figure the speedo being off factor
http://www.miata.net/garage/tirecalc.html
This is why I went from 205-65-15 to 225-60-15, there is only a ver minor speedo issue, not even big enough to notice.
Old 06-12-2005, 08:23 PM   #13 (permalink)
Rockin the STi
^i used the next one down on google "tire size"
http://www.1010tires.com/TireSizeCalculator.asp
04 WRB STi - Stg. 2
04 Suzuki GSX-R600
Old 06-12-2005, 09:38 PM   #14 (permalink)
Black 95 Camry
Peacemaker's Avatar
View Peacemaker's Photo Gallery
mine is now 205/55/16 runing great, grip is nice!
my baby G3N E.S
I'll never drive my car like this again...!
Peacemaker is offline   Reply With Quote
Old 06-13-2005, 07:56 AM   #15 (permalink)
Moving Forward
View Cyorke's Photo Gallery
if you use what they call puls sizing you should not have much trouble with speedo if it concerns you.
If stock is 205/65 you should be able to go to 215/60 and basically have the same size tire. 225/55 etc. same if you want to go to a more narrow tire. 195/70 should be pretty much the same size tire. Even saying that tires from different manufactureres that are the same size on the sidewall may not actually be the same size. You dont find it as much in passenger tires as you do flotation size truck tires. You can have 2 31" tires and one could actually be 30" and the other 32". It can happen on passenger tires but not as much ususally.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
