Wow, you picked a tough one for you first post. Like you said, the Haynes leaves you short on this one. With the delay thrown in, it may have something to do with the rear defog system. There is a timer in there, that through some strange way, may be causing this problem. You can try turning it on to see if it works properly, or try metering it first to try and find a short. Remember that if there is a delay in the fuse blowing, that there may also be a delay in the the short showing. That is just plain ugly.
If you have any info on earlier episodes, it has been going on for a year, it may help to narrow it down. Hot wires tend create more havoc as time passes, as they slowly melt through more and more wires.
