egr blockoff thoughts? (5s) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-13-2005, 12:55 AM   #1 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
I was just looking through a couple EGR system diagrams and realized that it seems the EGR valve's bottom vacuum line is the actual line that circulates exhaust gases.
If this is the case, could someone confirm it?
If so, I'm thinking of unplugging the vacuum line into the bottom of the EGR and simply using a vacuum cap with either a zip-tie or small hose clamp to tie it off. I'm guessing this method would not throw a CEL since the EGR is still in place and receiving vacuum.
thanks guys.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 06-13-2005, 01:16 AM   #2 (permalink)
View 500KCamry's Photo Gallery
I searched "EGR", and found this one ... there's a couple more I think.
http://www.toyotanation.com/forum/t68226.html
In addition to your mod your might have to substitute a fixed resistor for the EGR temp sensor.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-13-2005, 03:44 AM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
you would still need to bypass the temp sensor. anyways just pull the whole system out and make some block off plates
^ and leaving it that way!
Old 06-13-2005, 08:17 AM   #4 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
arent you running the ripp mods headers crawling eye?
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 06-14-2005, 11:26 AM   #5 (permalink)
Zzzz
yup.
The point of the thread is to not tear it out, but get around it.
I want it to remain in place so I can pass visual inspection. I can lean the shit out of the car with my S-AFC II to make it pass emissions.
-mark
