Car is squealing like crazy and it is not the brakes. Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-14-2005, 02:52 PM   #1 (permalink)
View bennington28's Photo Gallery
Well I have had this squealing noise for a while. I assumed it was the rotors because I installed brake pads 4000miles ago. The car squeals when I depress the brakes and when rolling at low speeds. It was driving me crazy, so..... I had the rotors resurfaced, installed new pads and applied antisqueal to the back of the pads. Well, the car still squeals, but not as much as before.What else could it be? Does the center bearing that supports the intermediate shaft have to be lubricated? Could the sound be coming from that cv joints or hub bearings? CV boots are not broken and there is no play when you pull on the axles.
1994 camry le wagon I4
bennington28 is offline   Reply With Quote
Old 06-14-2005, 02:55 PM   #2 (permalink)
Me and my Bebe, Bianca
CamryPunk's Avatar
View CamryPunk's Photo Gallery
Wheel bearings are bad. Get them changed.
Yukio Taira
-1992 4 door Bomex'ed out, Nitrous Express Sport'n, Rippmods SuperCharged Camry
-1992 4 Door EX Honda Civic 5 spd.
-2002 Subaru WRX Wagon... full JDM goodies. My new show car.
CamryPunk is offline   Reply With Quote
Old 06-14-2005, 03:11 PM   #3 (permalink)
View 500KCamry's Photo Gallery
Maybe the splash guard behind the rotor got bent and is hitting the rotor when it turns. I've seen some american made products that can trap a small stone or pebble in there too and it makes a squeeling noise.
Also the half axles for the various models of the camry are different, and the ones without ABS teeth has a metal dirt/debris stopper shroud that will not fit into an ABS steering knuckle without squeeling for example. I was wondering if this dirt/debris shround on your CV joint has become dislodged or trapped some dirt somehow. You would neen to pull the half axle out of the steering knuckle to inspect it.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-14-2005, 06:02 PM   #4 (permalink)
Is there a way to test to see if the bearings are bad? I would hate to shell out more money and it ends up not curing the problem.
Old 06-14-2005, 11:02 PM   #5 (permalink)
Moving Forward
View Cyorke's Photo Gallery
he only real way to check the wheel bearings is to jack the car up and grab the tire at the top and bottom as you are looking at it. There are specs as to how much it should move and I dont know what it is because they are wanting you to use a micrometer probably to test it the way Toyota says to. But you should not ahve any discernable movement when you move the tire back and forth while holding it on top and bottom. If you do have a lot of movement it is time to replace. The only thing is in my experience you typically do not get spuealing when the wheel bearings go out. Normally you will have waht sounds like a grinding at the wheel that has the bad bearing.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 06-14-2005, 11:06 PM   #6 (permalink)
View BuDDHa510's Photo Gallery
i got the same problem , havent got it fixxed yet.. so annyoing i got so much brake pad left also
BuDDHa510 is offline   Reply With Quote
Old 06-14-2005, 11:46 PM   #7 (permalink)
Yep.
And also when the bearing starts to go, sometimes you experience a vibration at a particular speed range, i.e. 80-85 km/hr for example.
01 XLE V6 310K km
Old 06-15-2005, 06:34 AM   #8 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
You sure its not just cheap brake pads? One of my friends got those lifetime brake pads from mineke and those things squeal like a bastard. cheap pads=higher metal content=more squealing
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 06-15-2005, 07:45 AM   #9 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Sometimes when the wheel bearing is bad you can hear it while driving and feel it. I know in my trooper one of the wheel bearings are bad and you can hear it and also feel the vibrations from it.
http://www.xclusive.bz
Old 06-15-2005, 10:30 AM   #10 (permalink)
View 97&02camryleI4's Photo Gallery
I have this same problem with squealing which sounds like brake pads are low. My fronts are still meaty so maybe it's the rear shoes? Do the shoes have those indicators on it? If it's not that then my brake pads are probably just causing the squeal sound even though they are OEM. My wheel bearings are fine since I don't notice any vibrations or hear it while driving. Plus there's not really any movement when I move the wheel side to side. Squeals only when I come to a stop slowly.
97&02camryleI4 is offline   Reply With Quote
Old 06-15-2005, 11:40 AM   #11 (permalink)
no vibrations from my car. just squeals at low speeds. brake pads are new
