Think I figured out CEL cause. How to turn off? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2005, 01:28 AM   #1 (permalink)
View Ranger X's Photo Gallery
I don't mean to reset it. I want it permanently off. I'm pretty sure it's a malfunction, as there are three seperate TSBs which suggest there could be a malfunction for code P0446. I had it looked at by three seperate mechanics and none could figure out what's wrong. So is there a way to disable that code from causing the CEL to come on? Or would I need a new computer or something? I mean, it has to be turned off for emissions inspection.
Ranger X is offline   Reply With Quote
Old 06-15-2005, 02:25 AM   #2 (permalink)
Local Rape Machine
View ekim55121's Photo Gallery
take out the cluster and remove the bulb
ekim55121 is offline   Reply With Quote
Old 06-15-2005, 02:54 AM   #3 (permalink)
Hah. Well, I guess that would work. Guess I didn't word my first post right, but I don't want to disable the CEL light completely, I just want it to turn off for this code, since it's malfunctioning. Is that not possible?
Old 06-15-2005, 06:24 AM   #4 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Dont know what kind of inspection you have in your area but if its the one where the plug into your car through the diagnostic connector, then taking the bulb out will cause you to fail. One of the tests they run is to make sure the chk. engine light works. If there is a fault in the system causing the code then the only way to pass will be to fix the problem. Replacing the computer wont change anything. It sounds like you need to find better techs. Any problem can be fixed, its just a matter of taking it to someone that knows what to look for and has the proper equipment and knowledge to check the system.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 06-15-2005, 07:46 AM   #5 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Yeah if you don't want to take out the bulb or you can't do it, then just find someone that can fix whatever it is.
http://www.xclusive.bz
