as far as i know, there would be a red light or red key blinking whenever you turn off your engine. This is like an internal alarm for the radio. If it is removed without the code, only the dealer can reset it.
1) did u buy the car new?
if Yes, go to No 2.
if NO, go to No. 3
2) Did you set up the alarm/security code for the radio? Based on your questions, I assume that it is NO.
3) Turn off engine. Remove key. Do you see a red light or red key blinking on the radio. No, that means that ur security feature on the radio was not activated.
As far as I know, the manual will tell you about the radio security setup. I read the manual over and over again for gen3 and gen4.
Paranoid, just go ask the toyota dealer. They will tell you for sure and it will be FREE
