Front seal oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2005, 02:43 PM   #1 (permalink)
View ballz2wallz's Photo Gallery
Unhappy Front seal oil leak
I have a front seal oil leak on my 94 5sfe (101,000 miles) . I am planning on changing the following while my car is down:
crank seal, water pump, idler pully (2), timing belt, alternator and ps belt, cam seal and oil pump seal, and thermostat.
Any other suggestions on what I should replace? Recommendations on best place to purchase these seals and belts and water pump (dealership or online)?
Any snags along the way I should know about?
Should I just follow the manual on timing belt removal and replacement as well as the Hanes manual for this procedure? I have read through the tech manual and there seems to be quite a few specialty tools involved. Can I rent most of these at autozone?
Thanks for all of your help!
BTW, A buddy is helping me and I will take pics throughout the entire process and post them later for future reference for anybody who does this on their own!
ballz2wallz is offline   Reply With Quote
Old 06-15-2005, 05:10 PM   #2 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
In reference to the oil leak, there are a few places, as far as I know.
1) oil pan
2) distributor o ring
3) cam seals
4) rear main seal
The rear main seal is a pain in the ass to fix.
You can rent tools at autozone, most if not all.
skewe is offline   Reply With Quote
Old 06-15-2005, 05:41 PM   #3 (permalink)
1) oil pan
3) cam seals
4) rear main seal
I am pretty sure it is the front and not the rear main. Also, not the oil pan. I was just trying to get an idea if there is anything else to change while I am in that region specifically.
Thanks
Old 06-15-2005, 10:39 PM   #4 (permalink)
View 500KCamry's Photo Gallery
On my 95 I've never changed the idler pulleys. Don't think they wear out that fast, unless you've had a water pump bearing leak.
You may want to change the tensioner spring and the oil pump gear set and o-ring. If you leave the oil pump body bolted to the block and there is no need to change the mating gasket.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-16-2005, 08:37 AM   #5 (permalink)
I have had no problems with my water pump so far....but I am going to go ahead and change it anyway while I am in there. I'll skip the idler pulleys then. I will change the tensioner spring..what about the tensioner pulley itself?
Also, the oil pump seal mates the pump to the block correct? Is this much of a pain in the ass to change if oil is not leaking from there? So you still think I should change the gear set and o-ring? Are you saying I can change the gear set and o-ring without removing the pump from the block?
Sorry for all the questions and thanks for your input!
