changing trans fluid... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2005, 11:46 PM   #1 (permalink)
View 92camryguy04's Photo Gallery
i got a 92 toyota camry LE, 4 cylinder auto.. its about time to change the trans fluid, so need some help. what kind of bolt is the trans drain nut? and is it just open the nut, drain, put nut on and fill fluid from up top? thanks
92camryguy04 is offline   Reply With Quote
Old 06-16-2005, 01:36 AM   #2 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
thats when you do an oil change. for tranny fluid, its shot in, not filled from the top
toyotaholic is offline   Reply With Quote
Old 06-16-2005, 12:43 PM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
10mm hex.
Yup.
The tranny is filled through the tranny dipstick.
http://www.toyotanation.com/forum/t76224.html
"Skoolin' the unlearned!"
Old 06-16-2005, 10:21 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
While you're at it, you might as well change the differential fluid also. You will need the same 10 mm hex drive and a 17mm wrench or socket to open the fill plug.
2007 Camry 2.4L 5M
