Hey Guys,
I am having some problems.
During a cold start (either in the morning, or when the engine has cooled down after a drive), right after you start the car there is a very loud buzzing noise.
It only goes away when the engine gets warm, if you accelerate soon after starting the noise comes back at around 2500RPM when accelerating and subsides when the engine gets warm.
Because this sounds like an odd thing, I got some footage of what is happening, sorry about the shaky camera work, but you will get the idea when you see/hear it. From what I can tell it's coming from the top left hand side of the motor.
server3.thegarage.com.au/wp/Camry.wmv
(sorry, but you need Windows Media Player to play it).
http://server3.thegarage.com.au/wp/DSCF2910.AVI (high quality)
I also have one more problem (again, only when cold and usually only in the morning).
If I don't let the car warm up (for around 5 minutes) just after I take off the power drops right down, the revs go down to around 500RPM and the car will either struggle up the hill and chug along for a few seconds or stall entirely. If I let the car warm up for over 5 minutes it takes off perfectly and there are no issues. And the acceleration problem goes away after doing it once, so even if I start off cold and let it chug along, right after it's had its fit it will accelerate fine.
Any ideas would be appreciated!
I have a feeling the noise part is a loose plate over the exhaust, but I am not entirely sure.
