KYB Struts and Mounts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2005, 06:55 PM   #1 (permalink)
View ptran's Photo Gallery
The KYB strut mount I bought only came with the upper portion (part visible under hood). The stock setup shows that there is another piece that connects to the bottom of this and holds the spring in place from the top where the struts holds spring in place from the bottom end. Am I to use the this stock bottom part and replace only the top mount piece?
Also the KYB boot looks nothing like the stock. The KYB has a pointed top whereas the stock is flat. Is this going to be compatiable?
ptran is offline   Reply With Quote
Old 06-18-2005, 08:19 PM   #2 (permalink)
View camlex's Photo Gallery
please check here
http://www.kyb.com/catalog/
camlex is offline   Reply With Quote
Old 06-19-2005, 10:34 AM   #3 (permalink)
View wanman75's Photo Gallery
The boot is completely different from stock which is what threw me too. I'll take some pics of the struts that I assembled. According to KYB, you can use the stock mounts from the stock strut. I purchased all new just because, though.
--- Procrastination ---
"Hard work pays off over time, but laziness always pays off now."
wanman75 is offline   Reply With Quote
Old 06-19-2005, 10:48 AM   #4 (permalink)
KYB Strut Boot pics
Here is what it should look like.
http://dcasrv9.ctfhotels.com/HPIM0234.JPG
http://dcasrv9.ctfhotels.com/HPIM0235.JPG
Question for you (if you have taken off the stock strut already):
When you look at it from the top, can you see any part of the spring, or is the top of the spring completely under the mount?
Old 06-19-2005, 03:16 PM   #5 (permalink)
Originally Posted by wanman75
Nice. On the stock setup the mount itself does not compress the spring. There's a plate that is attached to the bottom of the mount that holds the spring. So I was confused
As I remember (took the strut off a couple of days ago and had to reinstall because I was confuse) the entire spring was completely under the mount with nothing sticking out. Is this how it is with the KYB setup?
Also, how far did you force the boot down the strut and did you use the provide zip ties for the bottom of the boot?
Old 06-19-2005, 05:26 PM   #6 (permalink)
Oh shit... I'm missing the upper spring seat. That explains alot. I guess I should have ignored the pretty pictures KYB sent and just taken mine apart first. Great, more fun with the spring compressors.
Yes, I used the ties. There was one with the lower strut mount (the lower seat cover) and the one with the boot.
BTW, for those boots, lithium grease and a long flat screwdriver are your friends. Another pair of hands helps (to keep downward pressure on the boot, pushing it down the piston while you work the screwdriver around the sides), but doing it alone is possible, just harder.
Old 06-20-2005, 01:01 AM   #7 (permalink)
Oh shit... I'm missing the upper spring seat. .
Yeah, thinking this is what is getting to me. The KYB mount doesnt include the upper spring seat. So are we to use the stock ones?
BTW, for those boots, lithium grease and a long flat screwdriver are your friends. Another pair of hands helps .
How far did you force the boots down?
Old 06-20-2005, 06:28 AM   #8 (permalink)
Not sure. I'm going to call KYB (again) today and see what they have to say. The guy I talked to originally only said I had to use the stock lower seat, or the KYB replacement; he never mentioned the upper seat. Then again, I didn't ask.
As for the boot, I left the bumper just below the mount. I guess the bumper part is supposed to be as high as possible on the piston without interfering with the mount.
Old 06-21-2005, 02:06 PM   #9 (permalink)
Not sure. I'm going to call KYB (again) today and see what they have to say. The guy I talked to originally only said I had to use the stock lower seat, or the KYB replacement; he never mentioned the upper seat. Then again, I didn't ask. .
Lower seat? Which part is that? I thought the strut itself holds the bottom end of the spring together. Any luck with KYB?
Old 06-21-2005, 02:37 PM   #10 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112650
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
there are two parts to the upper mount. The part KYB sent you is only the top part with the bearing in it. Use the OEM lower part (the upper spring seat).
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 06-21-2005, 05:03 PM   #11 (permalink)
Now I'm really confused. The upper part of the mount I have doesn't have a bearing, only the lower part.
The GR-2 strut has a lower plate which has lip. The bearing sits on the lip. The spring seat goes over the lip and bearing. Then the insulator (lower) goes in the 'well' of the lower spring seat. The spring sits on the insulator. Is this different from stock somehow?
Here's the pic of the KYB instruction sheet: http://dcasrv9.ctfhotels.com/HPIM0238.JPG
I stopped by Toyota this afternoon to look at the OEM mount. Looks just like the KYB mount with the 'nubs' at the bottom of the studs (so the bottom surface isn't flat). Parts guy says 'no upper (OEM) spring seat, just the mount'. KYB says the same.
So... is there or isn't there an upper spring seat?
Old 06-21-2005, 06:11 PM   #12 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The pic in the thread below shows a upper spring seat.
http://www.toyotanation.com/forum/t83445.html
"Skoolin' the unlearned!"
Old 06-21-2005, 06:31 PM   #13 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
Yes Spring upperseat and as far as I know, 95-96 only had bearings, atleast tahts what I read in my haynes.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 06-21-2005, 06:58 PM   #14 (permalink)
Goal: Camry on Roids
View yungcamry8706's Photo Gallery
question, does kyb shocks wen u buy them come w/ lower insulator, springs bumper, and upper insulator, or are they already on the stock ones,,, sry for the question but the terms u guys are usin are confusing the heck outa me, but thats how i learn. thanks in advance....o and 88LE thanks for that thread u showed me w/ the pic, xplained alot....
yungcamry8706 is offline   Reply With Quote
Old 06-21-2005, 07:03 PM   #15 (permalink)
Lex Zues!
RedPhoenix's Avatar
You can thank me, it was my thread and my pic
A stock assembly has...
Strut
Spring
Lower Insulator
Upper Insualtor (also has the dirt gaurd on it)
Spring Seat (upper seat because the "lower" seat is permanently on the strut)
Bearing
Strut Mount
Sold ^
