Why must I always do stupid things? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2005, 08:03 PM   #1 (permalink)
Sold out for a Max
TheMajesticking's Avatar
View TheMajesticking's Photo Gallery
Well most of you know that I just recently put in a new radiator. Well. I failed to put one of the tranny fluid tubes on the bottom tightly and it came loose and leaked everywhere. It leaked to the point where the tranny wouldn't shift. I stopped and shut off immediately. Any idea how many quarts I may have lost? I also have no idea what kind of fluid it takes.(noob question) The dipstick says Dexron II. Help me.
-Chris
TheMajesticking is offline   Reply With Quote
Old 06-19-2005, 08:11 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
i think it takes around 6-7qt.. don't think dexon2 exist anymore but you can use dexon3
Old 06-19-2005, 08:12 PM   #3 (permalink)
Sold out for a Max
I used 2 1/2 quarts of dexron 3. I just want to know if I need to be changing it soon.
-Chris
Old 06-19-2005, 11:04 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
^ yes.....if your tranny over heated to that point, it means that you boiled whatever it may have been that actually had left in there.
and everytime your tranny oil overheats, it kills its lifespan to half....and if you actually push it to the point that you did...no idea....
I would give it a full flush for sure
HaHa
Old 06-19-2005, 11:13 PM   #5 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
I had a similar problem. I recently had my o2 sensor melt a hole through one of the tranny coolant lines. My rippmods header had relocated the o2 sensor to a place where it melted it. The strange thing is that I don't recall the problem when I installed the header nor did I have an issue until about 2-3 weeks ago. I noticed it when my car was being hesitant to shift. I checked the engine bay and at first didn't notice anything, since it apparently was just leaking when there was pressure (when the car was on) and shooting down. Once I located it, I put in a little over a quart of tranny fluid, replaced the line, bent the hardline to relocate it away from the o2 sensor and wrapped the area around it in 1750 degree heat shielding (since I had some in my garage yet from my exhaust) and no more problems.
It's not great for the tranny, but if it was only for a little bit of time, I doubt it'll cause much damage. You should do a flush/fill in the least.
I believe they only sell Dexron IV (or is it III?) now, all other tranny fluids are supposedly backward compatible so you should be good. I believe my car calls for Dexron II as well.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 06-20-2005, 07:29 AM   #6 (permalink)
Sold out for a Max
Ok. Cool. Thanks guys. I have always been terrified of flushing because of what I've heard about the tranny relying on the old fluid to run smoothly.
-Chris
Old 06-20-2005, 01:12 PM   #7 (permalink)
TN Pussy Man
^ if that happens, it means that your tranny was a bust anyways and could give out anytime as it was
HaHa
Old 06-20-2005, 03:18 PM   #8 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
it uses dexon3
skewe is offline   Reply With Quote
Old 06-20-2005, 03:35 PM   #9 (permalink)
View 500KCamry's Photo Gallery
"Why must I always do stupid things?"
LOL.
You're in good company, along with the rest of us.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-20-2005, 08:33 PM   #10 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
It takes a bunch of fluid if it all came out. They can refuse to shift if they're as little as a quart and a half off if the clutches are in bad shape.
Drive around 10 min, park, check the fluid at idle. You want it to read hot-full.
AIM/Yahoo Toysrme257th
Now with Turbo!
