Originally Posted by dragonzhalo
Just wondering if it is a good idea to get custom made cam gears and pulleys.
Cam gears won't do anything for our engines because of the design. The exhaust cam on our engines is driven off the intake cam by a internal gear. Theres only 1 cam gear which is bolted to the intake cam.
You can adjust the internal gears, but then your valve timing will be off and the car will run like sh*t.
Its not like on the GE head's were you have 2 cam gears. Our engines (FE) only have one.
Unorthodox makes aluminum crank pulleys. Their smaller and lighter then stock so they underdrive your accessories (alternator, powersteering, and a/c).
