valve clearance adjustment - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-21-2005, 07:20 PM   #1 (permalink)
View bluefever's Photo Gallery
I've noticed a noise from about 1,000 to 2,000 rpm's coming from the engine and I was wondering if the valves have to be adjusted
bluefever is offline   Reply With Quote
Old 06-21-2005, 08:10 PM   #2 (permalink)
View vicchang's Photo Gallery
First thing you can do is use high octane fuel to see if the noise is gone.
vicchang is offline   Reply With Quote
Old 06-22-2005, 03:48 PM   #3 (permalink)
i've tried it four times,i doubt that i keep getting bad gas from different stations
Old 06-22-2005, 03:59 PM   #4 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
stick to shell, chevron or texaco
u will be paying more though
skewe is offline   Reply With Quote
Old 06-22-2005, 06:30 PM   #5 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
stupid response but gas is gas..
i just stick to 76 station. You're getting teh same gas from everywhere. Do you actually believe that some stations run cleaner or better gas?
95WhiteCamry is offline   Reply With Quote
Old 06-22-2005, 06:37 PM   #6 (permalink)
jackfrost1031's Avatar
View jackfrost1031's Photo Gallery
I'm pretty sure all camrys have hydrolic lifters, so you shouldn't need to adjust valves like that.
1996 T100 2wd 5vz-fe
jackfrost1031 is offline   Reply With Quote
Old 06-22-2005, 07:20 PM   #7 (permalink)
TN Ass Man
DrtySthV6SE's Avatar
View DrtySthV6SE's Photo Gallery
what does this "noise" sound like
Pioneer Premier, Elemental Designs, SoundSplinter, Resonant Engineering Audio, Stinger, Optima, Rockford Fosgate
DrtySthV6SE is offline   Reply With Quote
Old 12-07-2005, 09:20 PM   #8 (permalink)
View drn151's Photo Gallery
gas
Yes most gasoline is the same but different companies add better additives than others, such as detergents.
drn151 is offline   Reply With Quote
Old 12-07-2005, 10:30 PM   #9 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
agreed.
the raw gasoline is the same, but the additives that make it run cleaner/smoother change by company.
you cant really adjust valves. you may hear clicking louder when the oil is low, or you need an oil change. you may hear it louder in cold temperatures. otherwise, it shouldnt be too bad. if there is a serious problem that warrants a head job, then you will KNOW when the sound is too bad.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 12-07-2005, 11:59 PM   #10 (permalink)
you could try getting new lifters
Old 12-08-2005, 12:29 AM   #11 (permalink)
View Gary_602Z's Photo Gallery
First thing would be to try to isolate/diagnois the noise. Could it be an exhaust sheild rattling or does it sound like it is in the motor? Can you replicate the noise with the hood up and throttling the engine manually?
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 12-08-2005, 09:35 AM   #12 (permalink)
Mr. DSM
Keep's Avatar
View Keep's Photo Gallery
Do the low-budjet stethoscope isolation test
Basically find a 2-3 feet peice of rubber vacuum line. Shove one end in your ear, and slowly move the other end around your engine head/block/manifolds/rocker arm cover/accesories/etc. until you find the source of thise 'noise'
Keep is offline   Reply With Quote
Old 12-08-2005, 09:40 AM   #13 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
What year is your car? What engine type? There was an intake "rattle at idle and accelleration" sound that was fixed with a new intake for 02-04 Camry's.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 12-08-2005, 11:47 AM   #14 (permalink)
View barthmonster's Photo Gallery
3rd Generation
I'm not sure about the newer Camry's, but all of the ones through at least '95 have non-hydraulic valves, meaning that as the camshaft and valve-tips wear, the clearance opens up, creating the sound you described. Best defense: get them adjusted and switch to synthetic oil such as Mobil 1.
barthmonster is offline   Reply With Quote
