throttle body cleaning/ fuel filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-21-2005, 09:07 PM   #1 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
3rd Generation throttle body cleaning/ fuel filter
so i bought this spray meant for cleaning your throttle body and etc.. i unhook the intake and there the butterfly thing is. the spray recommends to turn on the engine and while it is running, spray into the throttle body, working the butterfly manually. when i did this, the car stalled. is this normal? i did it again and it did the same thing. did this do any harm? i ended up cleaning it out with the spray while the car is off.. where else should i spray it in?
MrSo0h0o is offline   Reply With Quote
Old 06-21-2005, 09:30 PM   #2 (permalink)
View Skunkworks77's Photo Gallery
You need to rev it up more to spray it.
2001 Lexus ES 300 top of the line fully loaded.
1994 Toyota Camry with cleared lens and S2000 HID projector retrofit.
Skunkworks77 is offline   Reply With Quote
Old 06-21-2005, 09:41 PM   #3 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
Foot on gas, start the car up and keep reving it til it idles right.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 06-21-2005, 09:44 PM   #4 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Take it off and clean it. Too hard to make it spotless without removing it.
If you remove it, you can clean the whole damned thing instead of half way cleaning everything in it.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 06-21-2005, 11:10 PM   #5 (permalink)
MrSo0h0o's Avatar
also, i tried replacing my fuel filter but the nut on the bottom was way too tight. does anybody have some advice on how to do this?
after taking the top part off my fuel filter, i noticed my gas pedal sticks a little bit. it might be cuz of that or me adjusting the kickdown, im not sure. does this sound like any symptoms you guys have had?
Old 06-22-2005, 12:27 AM   #6 (permalink)
_trancemaster_
CamryMax's Avatar
View CamryMax's Photo Gallery
I got the same exact problem. I have brand new filter in the garage, but i can't get off othe old one. Its too tight
Toyota Camry '96 LE
I-4 Automatic
http://www.cardomain.com/
"Drive it like you stole it"
CamryMax is offline   Reply With Quote
Old 06-22-2005, 11:15 AM   #7 (permalink)
MrSo0h0o's Avatar
bump?
Old 06-22-2005, 01:12 PM   #8 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
search
lots of threads covered about replacing fuel filter.
skewe is offline   Reply With Quote
Old 06-22-2005, 03:04 PM   #9 (permalink)
skewe's Avatar
i would remove the trottle body if i was u.
makes it easier to clean. i scrub it with a tooth brush once i remove it.
Old 06-22-2005, 08:12 PM   #10 (permalink)
MrSo0h0o's Avatar
i have done a search.. none of them talk about the screw being so tight. im just trying to see if anyone had a solution to that. dont be all ready to jump on people and tell them to search. its not like im asking, "which is the gas and which is the brake.. derrrf"
Old 06-22-2005, 08:16 PM   #11 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ Use 2 wrenches. One to hold the filter and one to loosen up the fitting.
Look at the bottom of the filter and you'll see a hex section. You can place a wrench around the hex section to hold the filter.
Remove the filter from the car as the last step.
"Skoolin' the unlearned!"
Old 06-22-2005, 08:36 PM   #12 (permalink)
View camry93's Photo Gallery
whatever you do don't use a torch to heat it off. lol
camry93 is offline   Reply With Quote
Old 06-28-2005, 02:48 PM   #13 (permalink)
View digger1978's Photo Gallery
I remove the filter from the top of the engine compartment. You have to remove the air filter assembly to do this.
Make sure you have two open end wrenches to remove the filter. Use one wrench to hold the filter. Make sure the other wrench is a line wrench for the actual fuel line below. It looks different from a standard open end wrench.
It can be a little tricky to break the line fitting. The fitting is a different metal than the filter housing and over time they can stick together from the reaction of different metals.
What I did once I had it off was put a little anti-seize grease on the threads of the line fitting so the next time it wouldn't be such a pain to get off.
It is also a good idea to put anti-seize on the two bolts that hold the filter to the fender.
digger1978 is offline   Reply With Quote
Old 06-28-2005, 09:42 PM   #14 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Yeah when I changed mine on my 'clipse I had to use two wrenches to get that shit off. ONe to hold the filter and one to loosen the nut.
http://www.xclusive.bz
Old 06-29-2005, 02:29 AM   #15 (permalink)
Livers are for wusses
nobrainer's Avatar
View nobrainer's Photo Gallery
thanks guys... i didnt take mine off... yet.. i just opened her up and took a spray bottle of sea foam to it... I had trouble revving and spraying so i sort of sprayed and started it up to get that "smoke cloud from the muffler effect"
Mine was all white smoke so i guess that's normal?
I took a toothbrush to the body itself and i didnt get a great job... but i realize i had a crack in my coolant container so i'm probably gonna go ahead and do a flush when i figure all that out.. and while i'm doing it.. hell i'll just take off that throttle body and give her a good scrubbin
oh and i also wanna recalibrate my throttle cable because i think it might have loosened a bit so i'll mess with all that when i get time too
nobrainer is offline   Reply With Quote
