What's with the AC..? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-21-2005, 09:24 PM   #1 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
for some reason it sounds like the AC fan blowing the air into the car is jammed. It makes a loud humming noise and sounds like it is bogged down by something. Any ideas as to what this might be. This same exact thing has happened to my rolla as well. I can't figure out why its doing it, but every once in awhile it will just fix itself..
Corollacrazy42 is offline   Reply With Quote
Old 06-21-2005, 09:46 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
clean your car more offten. it prolly alot of dust/hair got cought up in the fan
^ and leaving it that way!
Old 06-21-2005, 09:48 PM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
Leaves, critters or small animals?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 06-21-2005, 11:33 PM   #4 (permalink)
That One Guy...
well ok.. assuming i make a mess of my car alot.. how would i go about getting to my fan to clean it?..
Old 06-22-2005, 02:42 PM   #5 (permalink)
Gameroom cash: $304355
It may also be an indicator that the bearing in the fan motor is starting to go. You can just drop the whole assembly and look at the "squirel cage" for something jamming it. If nothing is jamming it and the nut holding it to the fan motor hasn't come loose, then the bearing in the motor is going. The assembly is usually located on the passenger side underneath the dash. I haven't done one on a generation 4 yet, but essentially you remove whatever is in the way to get to it. Then it's usually one electrical connector and 3 nuts (or bolts) holding it in. You will have to lay on your back underneath the passenger side of the dash with a light to do this. If something is jamming it, it will probably fall out with the whole assembly.
Good luck.
Mike
Old 06-23-2005, 07:48 PM   #6 (permalink)
That One Guy...
haha well turns out mice like to live inside of my fan... so they put a bunch of paper and things inside of it and clogged it all to hell.. the fan was kinda hard to get out but was right where you said mike gerber.. thx for the help.. hope the mice dont strike again
Old 06-24-2005, 01:20 PM   #7 (permalink)
Corollacrazy42,
You're welcome.
Mike
Old 06-24-2005, 11:40 PM   #8 (permalink)
N/A bites
Tercel GTS's Avatar
Mice chew wiring also! Set traps if needed.
雄のハヤブサ
Old 06-24-2005, 11:56 PM   #9 (permalink)
That One Guy...
funny you should mention.. my prizm/rolla has the horn not working, the cruise control, and the fan isnt working just like the camry wasnt ( probably the f ing mice) since i have to keep my cars outside.. grrr.. but yea the mice probably chewed through the wires in that car too
