Camry electrical Q's - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2005, 09:41 PM   #1 (permalink)
Sleeper-still sleeping
Redline's Avatar
View Redline's Photo Gallery
3rd Generation Camry electrical Q's
I've already used the SEARCH option for the following topics, so don't jump to conclusions and call me a n00b BTW, I have a Haynes manual on hand, so maybe that can help and someone can point me to the correct chapter/pages
1)
A couple powered options have suddenly died in my car, and I'm looking for some answers before I start ripping my door apart. The things that are gone include: driver-side power lock (swtich not moving when I depress either of the door-side button) and passenger-side power window (will not move when either driver or passenger buttons are depressed). All other locks and windows work fine, but it's just these singular issues Anyone got ideas where I should start checking first?
2)
I read the Camry sticky concerning the procedure on coverting corner lamps (i.e. "parking lamps") into signal/blinker lamps. However, the steps seem a bit inadequate (sry 88LE...not to say your steps are completely useless ), so I was wondering if anyone had done this and maybe had more detailed steps or even pics. If no pics, then maybe I can be the first to document it.
That is all for now. Hopefully someone can help me out? THX!
Redline
2003 4WD XR Matrix
Mods: HID low-beams, Injen CAI, Pioneer mp3 H/U, Tein SS Coilovers, Hella foglights, Corolla TRD STB, TRD 17" alloys w/ General Exclaim UHP, stubby antenna, KVR cross-drilled rotors, 35% tint all-around.
Pending: DIY-fix for front lip kit...
Redline is offline   Reply With Quote
Old 06-22-2005, 09:57 PM   #2 (permalink)
View 500KCamry's Photo Gallery
The power locks, power windows, power seats and moonroof are all protected by a 30A (pink) fuse under the drivers dash. Since some of your features are working, the fuse is okay.
With the passenger window, I think its a wiring break in the door joint boot. Try operating the window with the door closed, half open and full open to see if the broken wire is intermittent. Search the threads there's instructions on how to repair.
The door lock I dunno, you'll have to take of the door panel to see if the probelm is mechanical or electrical. Could be the wiring, switch or the solenoid.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-23-2005, 08:50 AM   #3 (permalink)
View dstlaurent's Photo Gallery
For the passenger door lock, i have the same problem. i have solve the problem by add oil on the base of the lock buttom.
Bye
NOTICE: ANY TIME, XCUSE MY ENGLISH QUALITY ...
Camry Gen 3 1993
LE 3VZ-FE (V6)
236 000 km
dstlaurent is offline   Reply With Quote
Old 06-23-2005, 01:13 PM   #4 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
88 LE's parking light conversion works like a charm. I did on my Camry, it's the best and easiest solution out there. No need for relays. I also did it on the hamsterman's SpectraBlueHamster.
Silver Streak is offline   Reply With Quote
Old 06-23-2005, 05:15 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Originally Posted by Redline
2)I read the Camry sticky concerning the procedure on coverting corner lamps (i.e. "parking lamps") into signal/blinker lamps. However, the steps seem a bit inadequate (sry 88LE...not to say your steps are completely useless ), so I was wondering if anyone had done this and maybe had more detailed steps or even pics. If no pics, then maybe I can be the first to document it.
You dissing on my instructions?
Heres a thread with pictures:
corner lamp flashers
Any questions, just ask.
"Skoolin' the unlearned!"
Old 06-23-2005, 10:10 PM   #6 (permalink)
Redline's Avatar
^ sorry....like I said, I'm not saying that your instructions were unhelpful. It's just that I was unable to find other posts involving the conversion. I never meant to dis your instructions....not to a guru like you But thanks for the linked post excellent pics
one more quick Q about the lights. What kind of bulb did you use? was it a double filament? after the conversion, is the light able to stay lit even when it's not blinking? it's just that I want it to be like the "parking light" and then only flash when the blinker comes on. I hope you guys understand what I'm saying
thx for the help....more opinions/suggestions are welcome!
Redline
2003 4WD XR Matrix
Old 06-24-2005, 03:04 PM   #7 (permalink)
Grenaded piston
88 LE's Avatar
The bulbs were not changed.
The parking lights still function like normal. All your doing is rewiring it, so that it also functions as a blinker.
Old 06-24-2005, 05:11 PM   #8 (permalink)
spin turbo hammy... SPIN!
Hamsterman's Avatar
iTrader Score: 30 reviews
View Hamsterman's Photo Gallery
awww thanks man, i am glad you guys did that cuz it looks dope!
Lick first... ask questions later
Hamsterman is offline   Reply With Quote
