Mr.Alternator.com - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2005, 12:21 PM   #1 (permalink)
View OneLung's Photo Gallery
Question Mr.Alternator.com
i ordered a 150 amp alternator from mr.alternator and i just recently recieved it in the mail. Well i installed it and everything was all good, but like 4 days wen the car would idle the rpms would drop a little bit, the car would rattle hard, and the battery light would come on. so, i went out and bought a new battery, but it was still doing it, so i put in my old alternator and now everything works fine. is there any extra parts or anything for the higher amp alternator to work succesfuly??
OneLung is offline   Reply With Quote
Old 06-23-2005, 01:57 PM   #2 (permalink)
View karazy's Photo Gallery
You shouldn't need anything extra. You may have recieved a bad alt. Take it to autozone or equivalent to get it tested.
karazy is offline   Reply With Quote
Old 06-24-2005, 11:44 AM   #3 (permalink)
View oibone781's Photo Gallery
I say this to everyone, don't mess with Mr. Alternator. There alternators are horrible. Your car as to be about 2000rpms for you to get anywhere near that 150amp. Which means at idle it is putting out equal to the stock alternator. Down here in New Orleans there is a shop called Star Auto Electric, they rebuilt my stock alternator for 180amps for 250 or less. Don't mess with mr. alt. plus i went through hell just to get a refund..
oibone781 is offline   Reply With Quote
Old 06-24-2005, 12:56 PM   #4 (permalink)
Mr. DSM
Keep's Avatar
View Keep's Photo Gallery
You've already gotten a few good answers but i'll give my $.02.
First of all, if you dont know the theory behind alternator design and *flashing the alternator* dont even bother reading on.
I've had some customers buy aftermarket High output alternators that had different pinouts fot the internal regulator (some customers bought internally regulated alternators when their cars already were externally regulated)
Most cars flash the core when you start your engine, its done automatically. either controlled by logic from the ECU or straight from a hotwire on the battery terminal bus.
The problem with most aftermarket alternators is their pinouts and internal operation for flashing the field of the stator windings. Which leads to complete inefectiveness of current induction at low rotational speeds.
I advise customers with old hot rods to flash their alternators before installing them, (just in case the flash from the factory has worn off, it only takes 7 volts roughly) and because their electrical systers dont have the automatic logic to do so on original startup.
However if the supplyer will warantee their part and give you a new one, do that for their salesmen probably have no idea of the internal theory behind the operation anyway.
Keep is offline   Reply With Quote
Old 06-24-2005, 06:38 PM   #5 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
You went out and baught a battery just because the light came on???
That doesn't mean your battery is bad! It means CHECK your battery. You just wasted $90!
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
Old 06-24-2005, 08:39 PM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
Ready for some sincere advice? The rattle noise you heard was most likely the belt tensioner. The true higher current alternators create a much stronger resistance than the factory unit did and may wear out a used tensioner quickly. I'd reinstall the unit and watch for this.
I've heard several people claim that stock sized alternators were rebuilt to 180-250 amps for quite some time. I rebuild alternators for a living and have yet to see anything close. To relate the difficulty that'd be like saying you got 800ft/lbs of torque from a 4AGE and it gets 40mpg also.
Stock ND alternators are under rated. A 60a can normally make 80amps, 100a can make 140.... I'm going to get slightly technical here. The regulator that comes in a standard ND at full demand can only supply 5amps of field power. Partially this is due to the internal workings and part due to the regulator and alternator centralizing themselves from the remainder of the charging system under full load. With the regulator inside and hooked to a stator terminal the regulator can see the voltage as being too high during a spike load and actually power down. The way I correct this problem is to run an external regulator and one that can drive more than 5amps. My preferance is a ford type that is built by a company called Transpo. ( http://transpo-usa.com ) This style of regulator has 3 power inputs and one output so it can sense the voltage in one location while using a higher voltage feed to salvage the field power from. The particular units I use can supply 14amps of field power consistantly. ND rotors can pull 9 amps at 14 volts.
Stop by any other auto electric shop and request an amperage test while on the vehicle. Many will test for free while you watch for their own curiosity.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 06-24-2005, 10:36 PM   #7 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
Being an asshole is hilarious on the internet!
Seriously, quit being a dick
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 06-25-2005, 02:16 AM   #8 (permalink)
1990 Camry 5SPD
Skell's Avatar
View Skell's Photo Gallery
well would the same be true for a replacement starter then? (I got a 4cyl camry) I heard the V6 starters are rated at 14 or something, while the stock 4Cyclinder starters are rated at 10 or so.. some say if I got the 'stronger V6' starter itd help out in cold weather etc???? would the same logic for alternators apply to starters? should I just get another 4cyclinder starter????
90 Blue Toyota Camry 5SPD - current
00 Blue Subaru Impreza 2.5RS 5SPD - sold
00 Black Honda Accord EX V6 AUTO - trade in
88 Brown Toyota Van EFI AUTO - sold
Skell is offline   Reply With Quote
