VZ-FE owner coolant poll - Toyota Nation Forum : Toyota Car and Truck Forums
View Poll Results: Where does it stay?
1 bar 2 22.22%
2 bar 6 66.67%
3 bar 0 0%
4 bar 1 11.11%
Voters: 9. You may not vote on this poll
Old 06-24-2005, 03:55 AM   #1 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool VZ-FE owner coolant poll
Real simple...
VZ-FE owners only, where does your coolant gauge stay.
List your engine, and what it comes in. (if not obvious, like in your sig)
List if you ever had a cooling problem with it (bad coolant, bad hoses, bad thermostat, bad caps), and what caused that problem. (i.e. like old coolant at some point damaged the radiator, so it clogged and started leaking later on).
If you blew a head gasket, did it blow (normally) because the gasket, and head torque suck, or because the engine was having overheating problems before hand, resulting in the blown head gasket.
3vz-fe ES 300
Pin hole in radiator - caused from 10 year old coolant.
Registers at the first bar, only goes to the second on hot days.
Head gasket blew because it sucked ass.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 06-24-2005, 08:56 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
i voted 2 bar -- my needle stays just under 1/2 way, i have cheap green coolant, never had a problem with any of the hoses or any failure at all.
terrastrife is offline   Reply With Quote
Old 06-24-2005, 09:07 AM   #3 (permalink)
jackfrost1031's Avatar
View jackfrost1031's Photo Gallery
right under halfway
blew a headgasket once, temp guage never really went too hot as I drove only .3 miles with it, had it towed home. Think it blew because it was old (180k). Still sits about the same IIRC.
oh yeah, replaced the thermostat when i got it, would overheat easily, but realized later that it was a cooling fan problem.
1996 T100 2wd 5vz-fe
jackfrost1031 is offline   Reply With Quote
Old 06-24-2005, 09:41 AM   #4 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Same, right under the half way mark. On a hot day, gets to half way.
2VZ-FE VZV21
Never had a problem with coolant as such. Blew a top hose once, but it was old and ratty anyways. Think i've got a leak at the bottom hose/thermo housing area, as after a drive, i get a few drips. Apart from that, all good. Running Red coolant, not "Toyota Red", such a Red equiv. coolant to the green. No different really to the green stuff.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 06-24-2005, 10:15 AM   #5 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Ours ususally is right at the 1/2 mark
3vz-fe Camry
Replaced radiator/ cv joints/ driveshafts to the tune of 1400 bucks last summer
no overheating problems since.
**we replaced the radiator b/c it developed a hairline crack that coolant seeped out of (actually steamed) and caused overheating problems**
BlueFusion6851 is offline   Reply With Quote
Old 06-24-2005, 11:01 AM   #6 (permalink)
-=the wheel man=-
Killa_Kojak's Avatar
View Killa_Kojak's Photo Gallery
3VZ-FE it stays at 1/2 no matter how hard i drive.... 11530 km no problems so far and i hope it stays that way
1993 Toyota Camry LE Sport-Unnaturally Aspirated then killed
1997 Toyota Camry LE- aKa Purgatory Gray
Killa_Kojak is offline   Reply With Quote
Old 06-24-2005, 01:01 PM   #7 (permalink)
How hard can it be?
the only time ours buried was last summer after driving up and down pikes peak, we had driven another hour or so to the hotel and we parked and left it running, SCHWING! temp needle buried right then and there then we had it flushed at Toyota of Pueblo, CO, cause of iron deposites retaining heat.
Old 06-24-2005, 06:36 PM   #8 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
3vz-fe
Just under half way on average days. Cold days it doesn't usually make it all the way there. Never made it over half even reving my engine in 90 degree whether.
No coolant/radiator problems with over 211,000 miles on the car.
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
Old 06-26-2005, 04:21 AM   #9 (permalink)
View ezshift5's Photo Gallery
....just under the half;coolant shift(red to pink): at 75k.....along with repl radiator guard/front air dam............
ezshift5 is offline   Reply With Quote
