question about muffler - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2005, 04:23 AM   #1 (permalink)
Night Speed's Avatar
View Night Speed's Photo Gallery
4th Generation question about muffler
hi
i just uninstall my custom catback exhaust with resonator (pipe is 2.25" and muffler is magnaflow aluminized) and put back my stock pipe and muffler. i noticed that my car is faster.
why stock catback will feel faster? or i just think too much?
thanks
Night Speed is offline   Reply With Quote
Old 06-25-2005, 07:08 AM   #2 (permalink)
AlbertsGen2
View albertcua's Photo Gallery
Originally Posted by Night Speed
hi
thanks
it only feels faster because its quiet..thats what happens when you go from loud muffler to stock..
albertcua is offline   Reply With Quote
Old 06-25-2005, 07:52 AM   #3 (permalink)
View oibone781's Photo Gallery
Actually it is faster. I have 2.25 piping with a performane exhaust and drove a camry with stock exhaust and the car got up way quicker than mines...
oibone781 is offline   Reply With Quote
Old 06-25-2005, 03:25 PM   #4 (permalink)
View Mosquito's Photo Gallery
I noticed the same thing with my exhaust, slightly slower when accelerating, now that I'm used to it when I put stock back on it'll feel super fast..ha ha
Mosquito is offline   Reply With Quote
Old 06-25-2005, 03:30 PM   #5 (permalink)
TokyoRacer's Avatar
View TokyoRacer's Photo Gallery
Toyota put that diamter exhaust on for a reason. :P My fruiends civic with stock exhaust was quicker then most other civics with exhaust. Just depends on waht corresponding mods you do.
TokyoRacer is offline   Reply With Quote
Old 06-25-2005, 07:45 PM   #6 (permalink)
NIGHT STALKER
throwback's Avatar
View throwback's Photo Gallery
i dont believe that, because the more air flow goin through your exhaust system the better the acceleration/top speed/horsepower etc...so final conclusion is that aftermarket performance exhaust sytems are better. i felt a different speed and acceleration the minute i changed my 98 camrys exhaust
NIGHT STALKER
throwback is offline   Reply With Quote
Old 06-25-2005, 10:59 PM   #7 (permalink)
what kind exhaust system did you changed? and is your car I4 or V6?
thanks
Old 06-25-2005, 11:02 PM   #8 (permalink)
Nitrous Ab(user) ......
scdtrd's Avatar
View scdtrd's Photo Gallery
Exhaust piping diameter is VERY important. The LARGER the pipe.. (from stok) and the less restrictive, the LESS low end you will have and the more top end you will have. There is a LOT to flow dynamics in an exhaust system. Basically, the larger the diameter, and the lower the rpm, the quicker the exhaust will loose heat and flow. The larger diameter helps in the mid to upper RPM range. The stock piping is most likly the best for low to mid power with the stock engine. If you keep stock diameter, and make the system less restrictive, then you will gain good midrange.. a tad on the bottom and a fair amount on the top end.
Only if you port, polish and for forced induction, then you will reap more from the low end with larger piping. My suggestion, leave it alone, and remove the resonator, if you have a stock power plant. Stock = no porting, polishing, oversized valves, cams, turbo, S/C.. etc..
SCDTRD
1994 Toyota Camry V6 XLE I LOVE it!
And the journey continues........
scdtrd is offline   Reply With Quote
Old 06-25-2005, 11:12 PM   #9 (permalink)
SCDTRD
so you mean stick with stock pipe but remove resonator? and use performance exhaust?
thanks
