Only high setting works on the Fan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2005, 06:30 AM   #1 (permalink)
View FrankXT86's Photo Gallery
4th Generation Only high setting works on the Fan
Alright...well...recently the first 3 settings on my climate control have went out. It is either blasting out on High or nothing at all. Did the resistor pack blow out on the first three settings? or is it something else. Any ideas how to get this fixed and maybe how much?
TIA
1999 Toyota Camry LE
2.2L I4 (5S-FE)
Mobil-1 5w-30 Synthetic
130K+ Miles
BF-Goodrich Revelation Tires
FrankXT86 is offline   Reply With Quote
Old 06-25-2005, 07:07 AM   #2 (permalink)
AlbertsGen2
View albertcua's Photo Gallery
TIA
replace the switch
albertcua is offline   Reply With Quote
Old 06-25-2005, 07:53 AM   #3 (permalink)
View karazy's Photo Gallery
It is usually the resistor, like you said. The dealer wants about $50. I think there are some cheaper aftermarket ones out there. Shop around.
karazy is offline   Reply With Quote
Old 06-25-2005, 03:06 PM   #4 (permalink)
Gameroom cash: $304355
This is correct. It is the blower motor resistor. I didn't know of any available aftermarket. If someone does I would appreciate them posting the source.
Mike
Old 06-25-2005, 04:21 PM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
try a local junk yard..even though i had no luck i got 2 from the junk yard and my low still doesn't work so i'm thinking it's something else
Old 06-25-2005, 05:53 PM   #6 (permalink)
Where abouts is this resistor in the car? Under the hood or under the steering wheel or dash. Or is it in the climate control box thing itself where you actually turn the dial?
2.2L I4 (5S-FE)
130K+ Miles
Old 06-25-2005, 08:35 PM   #7 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
The resistor pack sits in the blower, usually accessible by the passenger footwell in the car. If you're any good, you can try and replace each invidual resistor yourself. I did that in my dad's Maxima years ago. Worked like a charm. Resistors are cheap, same with a soldering kit...you might as well try for fun, since you're planning on buying a new pack anyway. As well, go onto some engineering site and find out how to read the resistor bands....
Silver Streak is offline   Reply With Quote
Old 06-26-2005, 12:38 AM   #8 (permalink)
Thanks alot...ill try digging that guy up and see what he looks like tomorrow
2.2L I4 (5S-FE)
130K+ Miles
