Rear Strut Mount Location - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2005, 07:10 PM   #1 (permalink)
View ptran's Photo Gallery
changing my struts right now. i'm on to the rear, but cant seem to find the strut mount bolts so i can loosen it from the top. I tore apart all the lining in my trunk looking for it, but can seem to find them.
2000 v6 camry
ptran is offline   Reply With Quote
Old 06-25-2005, 07:12 PM   #2 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Did ya check under your rear parcel shelf?
old faithful
amerikim is offline   Reply With Quote
Old 06-25-2005, 07:37 PM   #3 (permalink)
no. where is that at?
Old 06-25-2005, 11:04 PM   #4 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
back seat has to come off first.
Old 06-25-2005, 11:38 PM   #5 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
PMd you, how did it go
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 06-26-2005, 07:48 PM   #6 (permalink)
Everything went well, except now the rear mounts makes lots of noise when I drive it over bumps. For this reason, I've kept it in the garage and out of commission.
The noise sounds like the mounts are not bolted no tight enough, so this allows the mount to moving free/wiggle around. I have tried to tighted all the the bolts (the 3 in a triangle form and the center one)
BUT the center one seems as though it can be tighten down more. everytime I wrench it, its spins along with the strut's piston, so all it is doing is spin round and round and not tighting.
Can someone please help
Old 06-26-2005, 09:34 PM   #7 (permalink)
Pochacco Owns Me
atobe's Avatar
you need an impact gun to get the nut on the strut to go all the way down... and you have to line it up too... cause there's 2 notches on the strut and same notches on the strut mount..
Old 06-26-2005, 09:47 PM   #8 (permalink)
Lex Zues!
RedPhoenix's Avatar
You dont need an impact gun, i did it with just a socket set.
Sold ^
Old 06-26-2005, 11:10 PM   #9 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
There's two notches cut out of the top of your strut, and two tabs sticking out the bottom of the strut mount. If you line them up correctly, they will keep the piston rod from spinning while you tighten it. One of my tabs on the rear mount somehow got bent back though, so it no longer holds them tight. If that's the case, you can either try to repair it yourself with whatever you have handy, or buy a new rear mount. Obviously, don't use tools to hold the rod in place... you will ruin the surface, and will quickly cause the new strut to blow.
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
Old 06-26-2005, 11:48 PM   #10 (permalink)
So you think the slots on both sides of the struts are not correctly aligned with the slots on the strut pistons? Damn, this means that I am going to have to removed the entire thing and reinstall?
Old 06-26-2005, 11:58 PM   #11 (permalink)
Lex Zues!
RedPhoenix's Avatar
I would. better to get it right, safer than sorry.
Sold ^
Old 06-27-2005, 11:31 AM   #12 (permalink)
Look what I found out: "most likely your problem is that these are cartridge struts, meaning your strut assembly stays the same and you just change out the insides. Now the problem is that whoever compressed and changed out your cartridge most likely didn't transfer the washer like spacer from your old cartridge over to your new one, therefore your cartridge isn't held in place tightly and when you hit a bump its actually moving inside the strut assembly."
Anyone know where these washer spacer's are they at? And I also do remember the struts included a washer for each, but didnt know where they go so I left them out. Anyone have any ideas?
Old 07-04-2005, 09:38 AM   #13 (permalink)
View markman's Photo Gallery
Sounds like a worn out strut mount. I just replaced my front mounts and am thinking about the rears but haven't done anything yet. On the old front mounts, the center nut would turn and turn. It's actually the rubber bushing, through a notched collar, that's supposed to hold the strut's shaft and keep it from turning. Once the rubber is shot, it will turn and turn. Sometimes as the bushing is wearing out, you can turn it a bit and effectively tighten the rubber, but a few months later the whole thing will be worse than before.
Everything I've heard says to always replace the mounts when replacing struts. I've got my original struts (ES300 - Japanese) but the front mounts were definitely shot at 100K miles. The ride firmed up a little with the new mounts, too. There's a little verticle shimmy that's gone, but it's also a little harsher.
FWIW, my original strut mounts had an oval opening at the top and the new replacement called out in some service bulleting had smaller round openings.
Don't forget to check your sway bar bushings and end links while your back there.
Let us know how it turns out.
markman is offline   Reply With Quote
Old 07-04-2005, 03:59 PM   #14 (permalink)
FINALLY got these bad boys in working condition. It turned out that the washers that came with the rear struts NEEDS to be utilized. I had to take the entire thing apart and place the washer under the center nut then reinstall.
I feel like pro working this project for about a week...so anyone have questions... ask.
Old 07-05-2005, 10:31 AM   #15 (permalink)
View wanman75's Photo Gallery
I'm doing mine (finally) tomorrow afternoon. Started yesterday on the rears only to get stymied by the bolts... I didn't have a deep 12mm socket.
Did you get an alignment after everything was done? Was it out much?
--- Procrastination ---
"Hard work pays off over time, but laziness always pays off now."
wanman75 is offline   Reply With Quote
