Hey man, well, if you wanted to get you wanted your tires to be low profile, meaning that there is a decrease in tire height from the rim to the top of the tire, then the lower the aspect ratio in P225/50R16 the lower the profile. So yeah P225/50R16 would be a better choice than the P225/60R16. If you wanna calculate the aspect ratio height for each tire size, just take the aspect ratio as a percentage in this case 0.5= 50% ex) P225/50R16 and multiply it by the tire width ex) P225/50R16. Hope that helps out your decision
