Factory Alarm Programing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2005, 06:48 PM   #1 (permalink)
View Mousiee's Photo Gallery
4th Generation Factory Alarm Programing
Can anyone help me w/ programing the factory alarm? I've searched but turned up empty handed.
My car is a 97 v6 XLE.
Is there a way to disable & enable the honk when arming alarm?
Honk twice when arming and honk once when unarming?
Can you rolled down the windows using the remote?
Or any thing else.
Any help is greatly appreciated.
Mousiee
Whips:
96 Lexus SC400
03 530i Sport
Mousiee is offline   Reply With Quote
Old 06-27-2005, 05:45 AM   #2 (permalink)
Also, can you adjust the sensitivity of the factory alarm?
Whips:
96 Lexus SC400
03 530i Sport
Old 06-27-2005, 08:21 AM   #3 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
Programming instructions for gen 4.5
should work with other gen camry.
if not, do a search for RS3200 or RS3000 on google.
http://www.golfballmall.com/camry/ca...e_program.html
u can adjust the sensitivity of the shock sensor. It is by the brake padals. Adjust it with a small screwdriver. it's a black box with a dial
skewe is offline   Reply With Quote
Old 06-27-2005, 08:23 AM   #4 (permalink)
skewe's Avatar
U cannot roll down windows with remote. Also, the remote does not have an option to do that,, unless u have a prototype remote from toyota that the public does not have.
Old 06-27-2005, 05:19 PM   #5 (permalink)
Thanks for the help.
My keyless remote programing instructions call for using the electric mirror plug. It says use a jumper wire to connect the 2 and 10 slots. Do you know if this jumper wire they're talking about can be any wire or is it a specific type of wire.
And I'll try to locate the shock sensor.
Whips:
96 Lexus SC400
03 530i Sport
Old 06-27-2005, 05:35 PM   #6 (permalink)
View steve97's Photo Gallery
No need for any special lead. Anything that conducts electricity. I used a paper clip. Works perfectly.
steve97 is offline   Reply With Quote
Old 06-27-2005, 05:38 PM   #7 (permalink)
I was just wondering if this was a programable feature. My Altima rolls down the windows by holding the unlock button on the keyless entry. There are quite a bit of thing that can be programed on the factory alarm. Here's an example:
Here are the settings you can change and the appropriate modes:
Door Lock/Unlock (with single click on keyfob)
Mode 1: Unlock left front door only
Mode 2: Unlock all doors
Anti-lock Out (prevents locking keys in car)
Mode 1: Master door lock switch can activate door locks w/ key in ignition
Mode 2: Master door lock switch cannot activate door locks w/ key in ignition
Dome Lamp Timer
Mode 1: Interior lamp comes on when left front door is unlocked
Mode 2: Interior lamp does not come on when left front door is unlocked
Dome Lamp Battery Saver (amount of time interior lamp stays on after closing the front door)
Mode 1: Interior lamp goes off immediately after shutting left front door.
Mode 2: Interior lamp stays on for 30 seconds after closing front left door.
Retained Power (Amount of time windows and sunroof will operate after turning off ignition)
Mode 1: 45 seconds
Mode 2: No delay (Will not operate after ignition key is turned off)
Mode 3: 2 minutes
Auto Light On (headlights turn on as it gets dark)
Mode 1: Factory setting
Mode 2: Lights come on sooner than factory setting
Mode 3: Lights come on later than factor setting
Mode 4: Lights come on later than Mode 3
Head Lamp Battery Saver (applies when headlights left in “on” position, not in “auto.”
Mode 1: Shuts lamps off after 5 minutes
Mode 2: No time delay (headlights turn off immediately)
Headlamp Illumination delay (time headlights remain on after exiting car when headlight is in the “auto” position)
Mode 1: 45 seconds
Mode 2: No Delay (lights turn off immediately)
Mode 3: 30 Seconds
Mode 4: 1 minute
Mode 5: 1 ½ minutes
Mode 6: 2 minutes
Mode 7: 2 ½ minutes
Mode 8: 3 minutes
Hazard and Horn Reminder Mode (key fob allows you to choose between modes 1 & 2, but there are 4 others)
Mode 1 (C Mode): Lock = 2 flash, 1 horn /// Unlock = 1 flash, 0 horn
Mode 2 (S Mode): Lock = 2 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 3: Lock = 0 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 4: Lock = 2 flash, 0 horn /// Unlock = 1 flash, 0 horn
Mode 5: Lock = 2 flash, 1 horn /// Unlock = 0 flash, 0 horn
Mode 6: Lock = 0 flash, 1 horn /// Unlock = 1 flash, 0 horn
Remote Auto Locking Function Mode (Doors automatically lock after exiting car)
Mode 1: 5 minute delay
Mode 2: Function disabled
Mode 3: 1 minute delay
Remote Panic Alarm Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Remote Trunk Open Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Remote Power Window Down Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: 3 seconds
Mode 3: 5 seconds
Just wondering if I can do stuff like this w/ the RS3000
Mousiee
Whips:
96 Lexus SC400
03 530i Sport
Old 06-27-2005, 10:49 PM   #8 (permalink)
skewe's Avatar
Mousiee,
As far as I know, camry are not there yet when it comes to power window rolling.
The RS3200 or RS3000 alarm does have some prog features like disable lights (outside), disable lights (inside-dome), honk once or not honk, anti-lock out..
No power window feature..
(as far as I know, or till somebody can prove that toyota has this feature).
I bought my car used, and it did not come with a alarm manual..
Old 06-28-2005, 06:16 AM   #9 (permalink)
I also brought my car used. I didn't know there was a alarm manual.
Right now my alarm just blinks twice to unarm and once to arm; do you know how to make it honk when arming?
Whips:
96 Lexus SC400
03 530i Sport
Old 06-28-2005, 10:59 AM   #10 (permalink)
skewe's Avatar
try the instructions..
i did managed to unhonk it after i bought it..
google search if that fails
Old 06-28-2005, 01:26 PM   #11 (permalink)
skewe's Avatar
Try this:
http://www.toyotanation.com/forum/t85541.html
Old 06-28-2005, 09:28 PM   #12 (permalink)
Thanks for your help. I programed my keyless entry transmitters today using the electric mirror plug. Now i'll search google to see if can get the honk back.
Mousiee
Whips:
96 Lexus SC400
03 530i Sport
Old 06-28-2005, 10:10 PM   #13 (permalink)
View Ranger X's Photo Gallery
What type of keyless do you have? Mine is a key with a built in a remote that says "securikey" on the back...haven't been able to find out much info on it. I tried programming it once when I first got the car, but the alarm is still kinda messed up. It goes off whenever it feels like it--i.e., during the middle of the night, waking people up. Hence why I have stopped using the remote to lock my doors.
Ranger X is offline   Reply With Quote
Old 06-28-2005, 10:22 PM   #14 (permalink)
skewe's Avatar
it should be the sensitivity of the shock sensor.
Adjust it with a small screw driver.
it is under the driver's dash
Old 06-28-2005, 10:28 PM   #15 (permalink)
Yeah, I've felt the shock sensor, but it's hard to see. Would it be easier if I removed the knee bolster and all that?
