Weatherstrip??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2005, 09:12 AM   #1 (permalink)
View 99camryLE's Photo Gallery
4th Generation Weatherstrip???
My driver side window won't go up properly...and when i looked at it, I saw that the weatherstrip along the A-pillar is wedged into the window, thus causing opposing force. The window is closed now, but it goes up very slowly. How do i get the weatherstrip out??? The strip strats to go inwards when the window is about half way up. Do I need to dismantle the whole door, or could a pry it out with a screwdriver or something???
Its not what u drive, its how u drive it!
99camryLE is offline   Reply With Quote
Old 06-27-2005, 09:16 AM   #2 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112650
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
flat head screwdriver. If it continues tho you may need to replace the stripping.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 07-07-2005, 10:39 AM   #3 (permalink)
View bnb1023's Photo Gallery
fixing window
The problem is that the window has jumped out of place. You will need to take off the panel, and move the rubber track back over the edge of the window. Then the window will come back up in the correct position. With electric windows, you need to pry up the controls to unhook the wires, then remove the various screws behind all of the tabs [about 6], pry off the inside mirror cover, and the panel will come off.
'98 Camry LE
bnb1023 is offline   Reply With Quote
