Weird acceleration problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2005, 11:34 AM   #1 (permalink)
View dstlaurent's Photo Gallery
When the engine is cold ... the acceleration is very weird (low and hi acceleration) ...
SYMPTOM:
The RPM go up like a stair ... in step ... example 2000 to 2100 and 2100 to 2300 RPM ... no middle ... and only when the engine is cold ...
do you know this problem ?!
Thanks
NOTICE: ANY TIME, XCUSE MY ENGLISH QUALITY ...
Camry Gen 3 1993
LE 3VZ-FE (V6)
236 000 km
dstlaurent is offline   Reply With Quote
Old 06-27-2005, 11:49 AM   #2 (permalink)
View Skunkworks77's Photo Gallery
Check the IAC valve. See if it is sticking.
2001 Lexus ES 300 top of the line fully loaded.
1994 Toyota Camry with cleared lens and S2000 HID projector retrofit.
Skunkworks77 is offline   Reply With Quote
Old 06-27-2005, 10:35 PM   #3 (permalink)
I know where is the IAC valve, but how i can chek if is sticking, and what i can do if is the case ....
Camry Gen 3 1993
LE 3VZ-FE (V6)
236 000 km
Old 06-28-2005, 12:24 AM   #4 (permalink)
Remove the two screws and there is a pin inside. Turn it with your fingers.
Old 06-28-2005, 07:00 AM   #5 (permalink)
Ok i will do that, before ... i have to change the gasket of the IAC after the manipulation ? And if the valve if realy sticky ... i put WD-40 or other lub on it ?
Camry Gen 3 1993
LE 3VZ-FE (V6)
236 000 km
Old 06-28-2005, 07:48 AM   #6 (permalink)
No need to change the gasket. Just open it and twist the pin loose. No need for grease either.
