what transmission fluid is right - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2002, 11:23 AM   #1 (permalink)
View PES300's Photo Gallery
Ihave flush the trans and switch to synthetic ATF the upshift becomes too smooth and has a feel of slipping what are you guys using
what is the oem atf fluid and what is toyota type II fluid?
PES300 is offline   Reply With Quote
Old 09-06-2002, 11:30 AM   #2 (permalink)
Gen2 Camry
View 91camryDX's Photo Gallery
I am using Dot 3, which is the OEM and it works just fine for me. I believe the synthetic is Dot 4.
1991 Toyota Camry DX: Mods listed on Cardomain
http://www.cardomain.com/id/whitecamrydx
91camryDX is offline   Reply With Quote
Old 09-06-2002, 12:47 PM   #3 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Toyota uses Dexatron III or type T. Look on your dipstick to see what you need to use. If it is Type t then must make sure you get type t and not dexatron III. Also Tranny Fluid is not reffered to as dot 3 or Dot 4. There is no such thing as dot 3 or 4 tranny fluid. The Fluid that is reffered to as dot 3 or 4 or 5 is brake fluid.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
