Squeaking Noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2005, 03:54 AM   #1 (permalink)
View CX889's Photo Gallery
Squeaking Noise
Recently, when I step the brakes, it creates a little squeaking sound. Like the squeaking sound when you open a door. Is it just because too much braking so the lubricant is not that well? Is it ok to spray some WD-40 to the brake joints? Thanks for your help!
2010 Venza V6 AWD / Magnetic Grey Metallic / Navi and JBL Package
CX889 is offline   Reply With Quote
Old 06-29-2005, 04:07 AM   #2 (permalink)
View 500KCamry's Photo Gallery
How about the pads being at the end of their life? Maybe you've hit the warning indicator.
Don't think WD-40 is good to use, the heat will burn it away. Think you have to use a high temp grease on the slide guides. Another poster will know for sure.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-29-2005, 04:26 AM   #3 (permalink)
Porbably I confused you, It's not from the brake, it's when you step into the brake. Even the car is fully stopped. You step it really hard, it will squeak. But the sound is not coming from the brake.
Old 06-29-2005, 07:17 AM   #4 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
it is coming from the brake padels.
spray some silicon grease on the moving parts on the padel
skewe is offline   Reply With Quote
Old 06-30-2005, 01:47 AM   #5 (permalink)
Any grease is fine?
