problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2005, 03:24 AM   #1 (permalink)
View asheik9201987's Photo Gallery
4th Generation problem
i have noticed a problem with my car. what happens is when it is left in the hot weather under the sun for 3-4 hours some smoke will come out of the exahust.
asheik9201987 is offline   Reply With Quote
Old 06-30-2005, 06:00 AM   #2 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
have u used seafoam lately??
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 06-30-2005, 02:30 PM   #3 (permalink)
no.what is seafoam and where would i use it on.also where can i get it?
Old 06-30-2005, 02:53 PM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
is the smoke only initial, or is it constanly pouring out under acceleration?
i fyou only get a small puff early on, that should be ok. but if theres more still coming out, you may have to get that check out ^^
terrastrife is offline   Reply With Quote
Old 06-30-2005, 04:17 PM   #5 (permalink)
0111010010
SnakeyeS's Avatar
seafoam is an engine cleaner but the only reason I ask is if you did use it, it generates a lot of smoke for a good amount of time.
Old 06-30-2005, 07:48 PM   #6 (permalink)
i'm not sure they might have used it at the shop when i got my exahust installed
Old 06-30-2005, 08:18 PM   #7 (permalink)
0111010010
SnakeyeS's Avatar
they shouldn't have unless you asked them to
Old 06-30-2005, 08:29 PM   #8 (permalink)
View yosh's Photo Gallery
You got a new muffler installed? How long ago was it and did the smoke start after the install?
2000 Camry LE V6
TRD Supercharged
yosh is offline   Reply With Quote
Old 06-30-2005, 09:52 PM   #9 (permalink)
i did this lik 4 months ago and is started up 2 months ago. it is a single puff that cumes out it's not constant
Old 07-01-2005, 01:46 AM   #10 (permalink)
a single puff is fine, its just leftover oil being burnt off. common in older 4 bangers.
Old 07-01-2005, 07:56 AM   #11 (permalink)
Mitsubishi Diamante Owner
CDub LXi's Avatar
View CDub LXi's Photo Gallery
Toyota told me that it's some kind of seal that is going bad when the car smokes at startup for a brief second after sitting for more than just a few hours (usually overnight). They said it's pretty expensive to fix so just live with it until it gets worse. They said it happens all the time.
CDub LXi is offline   Reply With Quote
