Please help someone Halo and Turn Signal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2005, 03:10 PM   #1 (permalink)
hollywood dropout
View couture's Photo Gallery
4th Generation My Cam.
How do you connect the halo wires to the turn signal for a 2001 camry? I did a search nother popped up.
couture is offline   Reply With Quote
Old 07-01-2005, 03:27 PM   #2 (permalink)
View atomic316's Photo Gallery
There is a red and white wire. White wire is for grounding, the best place for it will be found by removing the turn signal housing, you will find a bolt for grounding (there will be some wire connect to it already), loosen it a bit, and put the white wire there and tighten it (there are other similar grounding bolts, you can choose any one of it). The red wire will tap into the wire for the parking light. Cut open the protective plastic thing for the wires of turn signal light, 3 wires will be reveald, the wire you are interested in is green/orange in color. Tap into it, the halo will then work.
Written by TubbyC
atomic316 is offline   Reply With Quote
Old 07-01-2005, 03:31 PM   #3 (permalink)
hollywood dropout
so i connect the white wire to the any one of the ground wire and the red to the green orange color correct?
Old 07-01-2005, 03:40 PM   #4 (permalink)
yep
Old 07-01-2005, 03:43 PM   #5 (permalink)
hollywood dropout
thanks i got the right side, but the left side has no ground wire?
Old 07-01-2005, 04:04 PM   #6 (permalink)
You just have to ground the white wire, just find a bolt you can use to hold the wire. There's not need for another wire to be there.
Old 07-01-2005, 04:32 PM   #7 (permalink)
hollywood dropout
nevermind i got it, why toyota put it in such an odd place...took me awile to get that one but thanks for all your help
Old 07-03-2005, 06:35 PM   #8 (permalink)
hollywood dropout
Sorry, but i have another question, should the corner lights be on too? Is it legal to just have the angel eyes and not the corners on?
Old 07-03-2005, 10:11 PM   #9 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
not to be off topic, but i think you should get pics!
if the angel eyes are on your reg. headlights your corners should be on also, i belive
BlueFusion6851 is offline   Reply With Quote
Old 07-05-2005, 07:37 PM   #10 (permalink)
hollywood dropout
now my question is should my turn signal be on too? I'm pretty sure I disconnected the wire to hook up the angel eyes.. but should both be hooked up? I may have read what I was supposed to do to hook them up wrong.
Old 07-05-2005, 07:55 PM   #11 (permalink)
14.3@96mph
View thakidd's Photo Gallery
when i turn my turn on my angel eyes my turn signals are on 2..
"Happieness Is Being Blown"
thakidd is offline   Reply With Quote
Old 07-05-2005, 08:46 PM   #12 (permalink)
hollywood dropout
can you tell me how you hooked yours up?
Old 09-12-2005, 05:19 PM   #13 (permalink)
Jateg
View jateg's Photo Gallery
4th Generation
I made my own halos and I wired them into the running lights. The one thing you need to know about halos is that the electricity in the LEDS flows one way. In order for the LEDs to come on, you have to splice into the 2 outside wires that run to you blinker. Whenever you turn on your running lights, the halo will come on. And when you hit your blinker, the halo will blink then your actual blinker. Back and forth. Looks pretty kewl at night. Good luck with yalls.
I love ToyotaNation
jateg is offline   Reply With Quote
