It's just a bad set of pads, or a set that's prone to squeaking. A lot of the harder pads will squeak after being used hard until they wear a little bit.
Replacing the calipers wouldn't help.
Lastly - check the brake wear indicator against the pad left. A lot of times pads will wear abnormally quickly causing this problem.
AIM/Yahoo Toysrme257th
Now with Turbo!
