Engine temperature - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-05-2005, 02:10 AM   #1 (permalink)
View camreedude's Photo Gallery
Engine temperature
hello, I have a 1995 Camry LE. would like to know if someone can tell me if it is normal for my engine temperature to be close to the cold side on the gauge whenever I drive my car. This happens even when the weather is hot outside. Seems like the faster i drive the gauge shows my engine gets colder. Please let me know what is happening. do i waste more fuel this way?
camreedude is offline   Reply With Quote
Old 07-05-2005, 03:54 AM   #2 (permalink)
View karazy's Photo Gallery
The needle should stay in the middle or at least close to it. I would say that your problem is probably a sticky thermostat. The car is designed to be most efficient, when at it's optimal temp. In theory, it should be less efficient if the engine is constantly running cooler.
karazy is offline   Reply With Quote
Old 07-05-2005, 08:19 AM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
when your engine is running colder it burns more fuel because it's trying to warm up and your fast idel is still active.
your t-stat is bad put a pice of carbord to cover half your radiator and you should see it say about normal then. newer t-stats are made to fail in the open pos to keep the engine from over heating.
^ and leaving it that way!
Old 07-05-2005, 11:29 AM   #4 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
True, the engine has to run at a design temperature which is the middle of your temp gage. Up or down means abnormal. And must be dealt with. It could be a sticking gage.
mandyfig is offline   Reply With Quote
Old 07-05-2005, 11:41 AM   #5 (permalink)
ss4camry's Avatar
View ss4camry's Photo Gallery
Mine ran like that too but because the radiator was new. As soon as the radiator got a little older and sprang a couple of leaks the temp went to the middle and if i'm not careful it goes more to the H
92'camry 140k pay no attention
to the broken door handle
ss4camry is offline   Reply With Quote
Old 07-05-2005, 12:33 PM   #6 (permalink)
Breakin' necks since '02!
Durrby's Avatar
iTrader Score: 12 reviews
View Durrby's Photo Gallery
I have the same problem..Only my thermostat was just replaced.
Was told it's probably my "Coolant Temperature Sensor" Not sure if this is the issue with you car but most likey is with mine.
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
Durrby is offline   Reply With Quote
