exhaust bolts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-05-2005, 07:05 AM   #1 (permalink)
View slosh's Photo Gallery
4th Generation exhaust bolts
Tried searching but couldn't find anything. My g/f's 98 camry, 4cyl, has an oil leak. I think (hope) it's just the oil pan gasket. I was going to fix it but I have to remove the exhaust pipe and I can not get those exhaust bolts off back at the catalytic converter. They are rusted on there bad. I was about to just cut the pipe and take it in afterwards and have it welded back together. So can anyone help me out here and let me know how I could get those bolts off? Any tips or tricks? Thanks in advance.
slosh is offline   Reply With Quote
Old 07-05-2005, 08:01 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
spray it with some liquid wrench it's kinda acidic spray lube, leave it over night and try again if that fails try to located a impact wrench (air or eletric) and use that to take it off
^ and leaving it that way!
Old 07-05-2005, 08:49 AM   #3 (permalink)
I doused it with WD40 quite a few times. These things were so rusted I could barely get a wrench on them.
Old 07-05-2005, 09:00 AM   #4 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
Well liquid wrench is acidic. WD40 is just a lube.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 07-05-2005, 01:21 PM   #5 (permalink)
Gameroom cash: $304455
Keep soaking it with a good penetrating oil (PB blaster is good) not WD40 and keep trying. Heating it with a torch may be required to break really rusted bolts loose. A porpane torch might work if you have one or could borrow one. If they won't come off or you can't access a torch try taking it to a muffler shop and giving the guy there a few bucks to break them loose for you. I'm sure he will use his torch on them and then an impact.
Good luck.
Mike
Mike Gerber is online now   Reply With Quote
Old 07-05-2005, 01:30 PM   #6 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
I had the same issue, they were so rusted that when I grabbed them with a 12 point socket they just mashed so I tried vice grips so tight that I could barely close them with both hands... this was while bathing it in PB blaster for days...
I couldn't even cut through it with a sawzaw, finally I cut through the bolts with my dremel and cutoff discs (actually worked well).
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 07-07-2005, 11:16 AM   #7 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
I try and save the bolts by using a nut splitter, and use new nuts. Stainless would be nice, but not required.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Hajoca is online now   Reply With Quote
Old 07-07-2005, 03:05 PM   #8 (permalink)
Zzzz
a nut splitter won't work, you won't get one that will slip on the area (I tried that as well).
-mark
Old 07-07-2005, 03:10 PM   #9 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
You must rent an impact wrench.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 07-07-2005, 03:15 PM   #10 (permalink)
Zzzz
again, won't work, I tried an impact gun as well.
-mark
Old 07-07-2005, 03:33 PM   #11 (permalink)
View bassthrive's Photo Gallery
dremel cutoff discs worked for me too!
my bolts were so encrusted in rust, no amount of pb blaster could penetrate.
now with 100% more clickability
bassthrive is offline   Reply With Quote
