Custom Welded Camry Short Shifter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-05-2005, 02:13 PM   #1 (permalink)
Mr. DSM
Keep's Avatar
View Keep's Photo Gallery
Since I have not been able to find a short shifter for my 95 Camry 5S-FE,
I plan to make my own.
Also, I will make a VFAQ for this mod so others can follow this mod with ease.
First of all, I plan to cut and weld a 2"-3" slab out of the upper portion of the shifter (so it doesnt continue to look like a bus shifter)
If I am not pleased with that, I will add a section of metal to the lower two portions, and fabricate/adjust the bumpstops accordingly.
If anyone else has attempted this mod, or had a link or helpful hints to give to me before I begin the project, that would be greatly appreciated.
I'll keep you updated.
Kyle
Keep is offline   Reply With Quote
Old 07-05-2005, 03:19 PM   #2 (permalink)
限界域への独走。
View mobes's Photo Gallery
If you use one of these it will only require minor modifications to the base to clear the lower cable (where you need to grind will be obvious when you go to install it). It will fit a gen 4 shifter base with no mods at all.
mobes is offline   Reply With Quote
Old 07-05-2005, 03:33 PM   #3 (permalink)
Mr. DSM
Keep's Avatar
Thanks for the heads up, are there any special tools required to remove the actual shifter from the assembly?
I'm familiar with DSM shifters and these Toyota ones are very different (with that ball in the center)
Also, the shop manual does not go into shifter assembly overhaul at all.
Old 07-05-2005, 03:38 PM   #4 (permalink)
限界域への独走。
It's pretty straightforward. No special tools required. The tricky part is getting the nylon caps off the stock shifter to re-use on the short shifter. I used a small (10mm or so, whichever is the smallest that will clear the ball) open-end wrench in a vise to hold the nylon, and pounded the shfiter out with a punch and hammer.
Old 07-05-2005, 03:41 PM   #5 (permalink)
Mr. DSM
Keep's Avatar
Perfect, that was the part I was questioning (getting the actual shifter out of the nylon)
Nice 94 XLE btw, i browsed your cardomain
Old 07-05-2005, 03:43 PM   #6 (permalink)
限界域への独走。
I was reffering to the nylon bushings where the cables attach. The pivot bushing is slotted if I recall, so you can just pull.
Thanks for the compliment.
Old 07-05-2005, 03:51 PM   #7 (permalink)
Mr. DSM
Keep's Avatar
I misunderstood, but thank you for clearing that up.
My cardomain page In need of a major upgrade (old info, old pics. etc..)
Old 07-05-2005, 04:46 PM   #8 (permalink)
限界域への独走。
Looks like you have had quite a few nice cars. My dad had one of those Studebaker pickups when he was growing up.
Old 08-12-2005, 07:15 PM   #9 (permalink)
View koolkevin1107's Photo Gallery
Hey whats up. So ur saying a 00 celica short shifter will fit in my 4th gen camry? its a 98 camry CE w/ manual tranny. I hate the long ass throws. please help me out. thanks.
kevin
koolkevin1107 is offline   Reply With Quote
Old 08-13-2005, 03:49 AM   #10 (permalink)
限界域への独走。
kevin
Yes. It fits perfect.
