Emergency brake line HELP! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2005, 11:07 AM   #1 (permalink)
TN's ExercisePhysiologist
Bunthy's Avatar
View Bunthy's Photo Gallery
3rd Generation Emergency brake line HELP!
Ok, so I have a 96 avalon which is almost same as gen 3 camry. Anyways, I notice that my e-brake line isn't pulling tight. I check the pads and rotors (all newly replaced) and they weren't the problem. When I step in the e-brake, I notice the line pulls a little but not enough to tighten the pad against the rotors. Also after i disengage the e-brake, I need to pull the pedal back up with my foot to bring it back to its original height. Any idea on how to tighten the brake line or how I should go about fixign this because currently I do NOT have any form of emergency braking.....cept jumping out of a moving vehicle.......
You'll like being blown
Bunthy is offline   Reply With Quote
Old 07-06-2005, 06:25 PM   #2 (permalink)
Always Under Construction
View whocares04's Photo Gallery
the adjustment is underneath the center console, pick up a haynes manual, it'll tell u how...
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
Old 07-06-2005, 06:32 PM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
It's a drum-in disk brake - the pads shouldn't make contact with the rotors.
Take the rotor off and check the shoe.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 07-06-2005, 08:24 PM   #4 (permalink)
View Brujo's Photo Gallery
Or download a manual for a gen3 Camry (that's conveniently stickied at the top of this forum).
Brujo is offline   Reply With Quote
Old 07-07-2005, 11:49 AM   #5 (permalink)
Bunthy's Avatar
great, I'll d/l it today. Thanks alot.
Old 07-07-2005, 11:57 AM   #6 (permalink)
Moving Forward
View Cyorke's Photo Gallery
What Toysrme said. the disc part of the brake does not work as the parking brake. When you take the rotor off you will see there is a small set of drum brakes also. Those are for the parking brake. As far as the pedal not releasing, let me know what you find out because my 94 V6 Camry is doing the same thing but I am to lazy to mess with it. I really should use that brake though.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
